Upgrade to 12.x Self-hosted FIPS
For feature requests, please see: Mattermost | Operational and AI Sovereignty for Critical Infrastructure and National Security .
Getting a database migration error:
“could not compute MD5 hash: unsupported”
* Mattermost Enterprise 12.0.1
  • RHEL 9.8 running in FIPS
  • PostgreSQL 16.15 also in FIPS
Running Mattermost 11.x installation, perform upgrade to 12.x and it will be very unhappy about those MD5 hashes.
  • Successful update to Mattermost 12.x
  • The relevant error from PostgreSQL is “could not compute MD5 hash: unsupported”
  • Then it follows with dozensof lines of SQL statements
On self-hosted upgrades the sticky parts are usually TLS and the reverse proxy in front of the app: keep the public URL on https, make sure the proxy forwards the right headers, and re-check that Let’s Encrypt / cert paths still match after the version bump. Also worth confirming the service units or containers for the app and any job workers came back cleanly—upgrade can look fine while websocket or file uploads break behind a stale proxy config.
FIPS-mode Postgres refuses md5 outright, so pin down which layer calls it: a role password re-hash (fix: password_encryption=scram-sha-256, reset the role) or migration SQL. Which step throws it?
Yup. After a bunch of digging, I found found some interesting logs.
Mattermost is doing a bunch of calls similar to this:
CASE
    WHEN jsonb_typeof(o.opt->'id') = 'string'
         AND o.opt->>'id' <> ''
         AND o.idclaim = 1
    THEN o.opt->>'id'
    ELSE substr(
        md5(random()::text ||
            clock_timestamp()::text ||
            o.fieldid ||
            o.ord::text
        1, 26
END
The “md5(random()” is what is failing.
gen_random_uuid()
Would be a much better replacement.
Since we have a support agreement with MM, I sent everything to them and they agreed with the assessment but do not have a fix yet. (Didn’t remember about the support agreement until later unfortunately.)
Thanks.
One detail worth checking before replacing that expression with gen_random_uuid() is the expected ID format.
The current migration takes the first 26 characters of an MD5 hex string, while gen_random_uuid() returns a 36-character UUID with hyphens. If the destination column or application code expects the existing 26-character format, a direct replacement may introduce a different failure.
A possible alternative would be to generate a UUID, remove the hyphens and truncate it to the expected length, assuming that format is actually required. But I’d want to check the column definition, uniqueness constraints and any application-side validation first.
Since Mattermost support has already acknowledged the issue, I’d avoid modifying an applied or pending production migration locally unless they provide an approved workaround. Otherwise a later upgrade could become harder to reconcile.
It might also be worth having the fix covered by a migration test running PostgreSQL with FIPS restrictions enabled. That would catch this class of problem before the next release.
The important part seems to be preserving the ID contract while removing the dependency on MD5.
