Upgrade v9.6 to v10.5 and mysqlDB migration failure
I am coming from MM version 9.6 upgrading to 10.5. Last upgrades were a breeze, which I love, but my neglect to upgrade lately and having to jump to 10.5, just doing the simply upgrades failed because there are DB changes. Jumping the gun!
Anyway, after reading the [important-upgrade-notes]. (Important Upgrade Notes - Mattermost documentation)
I can see there are changes in the DB, and I would like to know if I did this correctly. IT did work, but needed a little extra mysql_upgrade -root -p at the end because there was a complaint in the logs when I tried to systemctl start mattermost
Cannot load from mysql.proc. The table is probably corrupted
I took the db commands from v10.6 in the ā€˜important-upgrade-notes’, vim them in a file.sql and did mysql -uroopt -p mattermost < file.sql, which did target the mattermost db and created the new tables with ect.
But once I continued with the upgrade steps, it still crashed with the error above. Only searching online about ā€˜Cannot load from mysql.proc. The table is probably corrupted’ led me to run mysql_upgrade -root -p. All is good.
I can’t be the only one running into this? And what exactly happens here, mysql refreshes its cache of tables so starting mattermost will read them properly? I am curious…
Sucks that V11 you need to use psql cause I was just fine with mysql, even though I’m sure psql will probably introduce performance improvements.
Our recommended upgrade strategy is to get to the first available ESR (9.11.9) and then go to 10.5.1
