Username and OIDC integration
Hi Team,
I tried to run some tests in Mattermost Cloud to evaluate Mattermost Enterprise Edition.
After setting up OIDC (OpenID Connect), I found that Mattermost tends to use the user’s email prefix as the username instead of the preferred_username provided in the OIDC Profile.
Is there any way to change this setting?
Thanks.
Hello, @Zero
While the OpenID Connect documentation does not explicitly mention if there is any possibility of configuring specific attribute for username, may I know if you are open to create a suggestion in Mattermost Uservoice?
Let me know if you prefer me to raise it on your behalf. Thanks.
Hi, @ahmaddanial
I have created UserVoice suggestions.
However, using the preferred_username claim as a username is part of the OIDC specification, so please consider a more standardized implementation of OIDC.
  • Claim Name: preferred_username
  • Claim Description: Shorthand name by which the End-User wishes to be referred to
  • Change Controller: OpenID Foundation Artifact Binding Working Group - openid-specs-ab@lists.openid.net
  • Specification Document(s): Section 5.1 of this document
Hi again, @Zero
Got it and thanks for the details. I am putting the link out here for reference purposes for other users who are also interested with the same implementation of OpenID Connect:
Note that these claims are only intended as hints for registration, hints for login (i.e. ask the user to provide their password etc but autofill the username/email),or potentially update details. Neither value should be leveraged for allowing users to login or determining which client account to use for any purpose.
I have the same problem. Has this still not been addressed since 2021?
