Using Gemini with Copilot
Is it possible to use a Gemini API Key with Copilot? Currently I only see OpenAI, Anthropic an Ask Sage.
Thanks
Hey @Greg_V,
Thanks for reaching out about this. Currently we do not support the Gemini API in the current iteration of the plugin, but there is a GitHub issue about adding support โ€“ and you might find some of the resources there helpful: ๐Ÿ’ก idea: add google gemini to list of supported backends ยท Issue #161 ยท mattermost/mattermost-plugin-ai ยท GitHub
