I have this interactive message that includes a button. When it’s clicked, it should send a POST request to http://localhost:3000/mm:
channel_id: chan.id,
props: {
attachments: [
text: 'This is the attachment text.',
actions: [
integration: {
url: 'http://127.0.0.1:3000/mm',
context: {
action: 'do_something_ephemeral',
It looks like this:
But when I click I have this error (and the request is not received by the api)
"id": "api.post.do_action.action_integration.app_error",
"message": "Action integration error.",
"detailed_error": "err=Post \"http://127.0.0.1:3000/mm\": dial tcp 127.0.0.1:3000: connect: connection refused",
"request_id": "qjgh4nz8k7fjix53maxkyoi48y",
"status_code": 400
But when I do a simple curl like curl -XPOST http://localhost:3000/mm, my api received the request.
Note that I’ve modified the untrusted connections and it looks like this
Also my mattermost server is running on localhost. Executed with this command:
docker run --name mattermost-preview -d --publish 8065:8065 mattermost/mattermost-preview
Any hint on this issue?
