Using apache2 vhosts for gitlab + mattermost on the same machine, letsencrypt for SSL, gitlab SSO fails with “Bad token type”
On a clean Ubuntu 16.04, install gitlab-ce [ GitLab Community Edition 8.14.1 e45bf3d ] and letsencrypt. Have DNS for example.com, git.example.com, and chat.example.com all pointing to that same machine, and get certs for all three. Configure gitlab’s nginx to run on port 8001, and mattermost by default runs the service on localhost:8065. This is the /etc/gitlab/gitlab.rb:
external_url 'https://git.example.com'
gitlab_rails['gitlab_email_from'] = 'gitlab@example.com'
nginx['enable'] = true
nginx['ssl_certificate'] = "/etc/letsencrypt/live/example.com/fullchain.pem"
nginx['ssl_certificate_key'] = "/etc/letsencrypt/live/example.com/privkey.pem"
nginx['listen_port'] = 8001
mattermost_external_url 'https://chat.example.com'
mattermost['enable'] = true
mattermost['service_use_ssl'] = true
mattermost_nginx['enable'] = false
Apache2 vhosts are used to redirect https://git.example.com and https://chat.example.com to the right ports:
<VirtualHost *:443>
ServerName git.example.com
<Proxy *>
Require all granted
</Proxy>
SSLProxyEngine on
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
SSLProxyCheckPeerExpire off
ProxyRequests Off
ProxyPass / https://127.0.0.1:8001/
ProxyPassReverse / https://git.example.com/
RewriteEngine on
RewriteCond %{DOCUMENT_ROOT}/%{REQUEST_FILENAME} !-f
RewriteRule .* https://127.0.0.1:8001%{REQUEST_URI} [P,QSA]
# needed for downloading attachments
DocumentRoot /opt/gitlab/embedded/service/gitlab-rails/public
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/example.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/example.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
and
<VirtualHost *:443>
ServerName chat.example.com
SSLEngine on
ServerSignature Off
ProxyPreserveHost On
ProxyRequests Off
# Ensure that encoded slashes are not decoded but left in their encoded state.
# http://doc.gitlab.com/ce/api/projects.html#get-single-project
AllowEncodedSlashes NoDecode
DocumentRoot /var/opt/gitlab/mattermost
RewriteEngine on
RewriteCond %{REQUEST_URI} ^/api/v1/websocket [NC,OR]
RewriteRule .* http://127.0.0.1:8065%{REQUEST_URI} [P,QSA,L]
RequestHeader set X-Forwarded-Proto "https"
<Location /api/v1/websocket>
Require all granted
ProxyPassReverse http://127.0.0.1:8065
ProxyPassReverseCookieDomain 127.0.0.1 chat.example.com
</Location>
<Location />
Require all granted
</Location>
</VirtualHost>
You can log in to Mattermost using Gitlab SSO
Clicking on Gitlab Single-Sign-On sends me to Gitlab [ git.example.com ] to log in, which succeeds.
I get a prompt to "Authorize GitLab Mattermost to use your account?"
I click “authorize”, which sends me back to chat.example.com with the error:
GitLab Mattermost needs your help:
Bad token type
Go back to Mattermost
In the logfile /var/log/gitlab/mattermost/mattermost.log, I have the error
[EROR] /signup/gitlab/complete:AuthorizeOAuthUser code=500 rid=<###> uid= ip=<###> Bad token type [details: token_type=, response_body=]
