Hello, need some help
Mattermost 7.1.1
Database Schema Version: 89
DB: mysql
I’ve got problem with big threads:
Failed to load resource: the server responded with a status of 502 ()
{"id":"api.context.404.app_error","message":"Sorry, we could not find the page.","detailed_error":"There doesn't appear to be an api call for the url='/api/v4/posts'. Typo? are you missing a team_id or user_id as part of the url?","status_code":404}
How can I debug it?
The problem starts when a thread gets anywhere from 30-40 posts.
The problem was that the timeouts (Write, Read, Idle) were set incorrectly. I changed all the values to 300 and the error went away.
Hi @underdark456 , welcome to the Mattermost forums and thanks for providing the solution to your problem!
What were the values before? The default values for these variables are:
# mmctl --local config get ServiceSettings | grep -m3 Timeout
"ReadTimeout": 300,
"WriteTimeout": 300,
"IdleTimeout": 60,
Hey @agriesser
The timeouts may have migrated from the test base mm, which was deployed through your operator, there was still a cluster size to specify, maybe there were ok small timeouts on the small one
