Can not able to call login api
Screenshot%20from%202019-01-05%2016-50-10
Hi @parikshit,
What Mattermost server version are you using?
What Gitlab version are you using?
Can you help read through this earlier thread to see if it helps you resolved the issue: Impossible to log-in using v4/api?
