Configuring Mattermost Operator Kubernetes - Site URL
Hi everyone,
i deployed mm in a kubernetes environment using the mm operator. Is it possible to edit the value of the Site URL anywhere in the mm deployment using the mm operator?
I tried to change the spec.ingressName in the installation manifest but it didn’t worked.
It is not possible to change the setting value through the System Console since it has been set through an environment variable.
I’m trying to disable TLS and set a specific port, changing the value from
https://mattermost.example.com to
http://mattemost.example.com:32421
Thanks in advance,
