Data retention settings in config / Clear posts
is there a chance of getting the data retention settings to work, if not using Enterprise edition?
They are active here like:
"DataRetentionSettings": {
    "EnableMessageDeletion": true,
    "EnableFileDeletion": true,
    "MessageRetentionDays": 5,
    "FileRetentionDays": 5,
    "DeletionJobStartTime": "02:00"
but are not working.
Is there any possibility for non enterprise users to implement this behaviour via another approach?
At the moment I use the SQL-Command: TRUNCATE TABLE posts for this. It works, but isn’t it a little bit “hardcore”
Thanks!
Hi @mcdaniels,
Unfortunately Data Retention is only available in E20: https://docs.mattermost.com/administration/data-retention.html.
@amy.blais
I read this in the docs, but hoped that it is somehow available :wink:
BTW: Mattermost is a real great product! Keep up the good work!
