Please provide instructions to setup developer machine on debian.
Hi Maksadbek,
We are working on some new install instructions, including developer instructions. We don’t have specific Debian instructions. However it should be similar to the setup instructions found here: https://github.com/mattermost/platform/blob/master/scripts/README_DEV.md
The only thing to note is on linux you do not need to use boot2docker. You should follow the docker install instructions found here: https://docs.docker.com/installation/debian/
Then add a line to your /etc/hosts that goes 127.0.0.1 dockerhost because your dockerhost is your local machine.
Let me know if you run into any troubles.
Christopher
