Docker - cant create private and public channels
I installed docker version of mattermost. Unfortunately i dont see PLUS character near Public and Private channels to add any. My config/config.json from inside of contaier seems to be fine.
   "TeamSettings": {
    "SiteName": "Mattermost",
    "MaxUsersPerTeam": 50,
    "EnableTeamCreation": true,
    "EnableUserCreation": true,
    "EnableOpenServer": false,
    "EnableCustomBrand": false,
    "CustomBrandText": "",
    "CustomDescriptionText": "",
    "RestrictTeamInvite": "all",
    "RestrictPublicChannelManagement": "all",
    "RestrictPrivateChannelManagement": "all",
    "RestrictPublicChannelCreation": "all",
    "RestrictPrivateChannelCreation": "all",
    "RestrictPublicChannelDeletion": "all",
    "RestrictPrivateChannelDeletion": "all",
    "RestrictPrivateChannelManageMembers": "all",
    "EnableXToLeaveChannelsFromLHS": false,
    "UserStatusAwayTimeout": 300,
    "MaxChannelsPerTeam": 2000,
    "MaxNotificationsPerChannel": 1000000,
    "EnableConfirmNotificationsToChannel": true,
    "ExperimentalViewArchivedChannels": false,
    "ExperimentalHideTownSquareinLHS": false,
    "ExperimentalTownSquareIsReadOnly": false,
Hi @dominikp, does changing ``“EnableXToLeaveChannelsFromLHS” to True change what you are seeing?
I changed that value inside container, cleared browser cache and restarted it (browser) and it didnt work.
How many channels do you have on that team?
We also have these two bug tickets that might be related to the issue you’re seeing:
None, i just started a docker instance for some tests and from the beginning i cant add any channels.
Just want to point out that I’m also facing this issue. I can archive/unarchive/close channels, but the button to create a new channel is not shown. I’m using docker too (mattermost/mattermost-team-edition:release-6.0).
Mattermost Team Edition
Mattermost Version: 6.0.0-rc1
Database Schema Version: 6.0.0
Database: postgres
well, the create button is located here
i have the lastest MM installed.
Is it maybe the docker version? I created now a very simple demo to simulate the problem.
The docker-compose.yml full file:
version: "3.7"
services:
  mattermost:
    image: "mattermost/mattermost-team-edition:release-6.0"
    restart: "unless-stopped"
    depends_on:
      - "postgres"
    ports:
      - "8080:8065"
    environment:
      MM_USERNAME: "mattermost"
      MM_PASSWORD: "111222"
      MM_DBNAME: "mmdb"
      DB_HOST: "postgres"
      DB_PORT_NUMBER: 5432
    volumes:
      - "./env/mattermost/config.json:/mattermost/config/config.json"
  postgres:
    image: "postgres:13.3"
    environment:
      POSTGRES_USER: "mattermost"
      POSTGRES_PASSWORD: "111222"
      POSTGRES_DB: "mmdb"
The only setting in the config.json file that was changed regarding the original that comes in the image is SqlSettings.DataSource, that was changed to postgres://mattermost:111222@postgres:5432/mmdb?sslmode=disable\u0026connect_timeout=10.
The config.json file that was mapped:
    "ServiceSettings": {
        "SiteURL": "",
        "WebsocketURL": "",
        "LicenseFileLocation": "",
        "ListenAddress": ":8065",
        "ConnectionSecurity": "",
        "TLSCertFile": "",
        "TLSKeyFile": "",
        "TLSMinVer": "1.2",
        "TLSStrictTransport": false,
        "TLSOverwriteCiphers": [],
        "UseLetsEncrypt": false,
        "Forward80To443": false,
        "TrustedProxyIPHeader": [],
        "ReadTimeout": 300,
        "WriteTimeout": 300,
        "IdleTimeout": 60,
        "MaximumLoginAttempts": 10,
        "EnableCommands": true,
        "GoogleDeveloperKey": "",
        "EnableLinkPreviews": true,
        "EnablePermalinkPreviews": true,
        "RestrictLinkPreviews": "",
        "EnableTesting": false,
        "EnableDeveloper": false,
        "EnableOpenTracing": false,
        "AllowCorsFrom": "",
        "CorsExposedHeaders": "",
        "CorsDebug": false,
        "SessionLengthWebInDays": 30,
        "SessionLengthSSOInDays": 30,
        "SessionCacheInMinutes": 10,
        "WebsocketSecurePort": 443,
        "WebsocketPort": 80,
        "WebserverMode": "gzip",
        "EnableGifPicker": true,
        "GfycatAPIKey": "2_KtH_W5",
        "GfycatAPISecret": "3wLVZPiswc3DnaiaFoLkDvB4X0IV6CpMkj4tf2inJRsBY6-FnkT08zGmppWFgeof",
        "EnableCustomEmoji": true,
        "EnableEmojiPicker": true,
        "PostEditTimeLimit": -1,
        "EnablePostSearch": true,
        "EnableFileSearch": true,
        "MinimumHashtagLength": 3,
        "EnableUserStatuses": true,
        "EnableTutorial": true,
        "EnableOnboardingFlow": true,
        "EnableAPIUserDeletion": false,
        "EnableEmailInvitations": false,
        "EnableSVGs": false,
        "EnableLatex": false,
        "EnableAPIChannelDeletion": false,
        "EnableLocalMode": false,
        "LocalModeSocketLocation": "/var/tmp/mattermost_local.socket",
        "EnableAWSMetering": false,
        "SplitKey": "",
        "FeatureFlagSyncIntervalSeconds": 30,
        "DebugSplit": false,
        "ThreadAutoFollow": true,
        "CollapsedThreads": "disabled",
        "ManagedResourcePaths": "",
        "EnableReliableWebSockets": true
    "TeamSettings": {
        "EnableCustomUserStatuses": true,
        "MaxNotificationsPerChannel": 1000,
        "ExperimentalViewArchivedChannels": true,
        "LockTeammateNameDisplay": false,
    "ClientRequirements": {
        "AndroidLatestVersion": "",
        "AndroidMinVersion": "",
        "DesktopLatestVersion": "",
        "DesktopMinVersion": "",
        "IosLatestVersion": "",
        "IosMinVersion": ""
    "SqlSettings": {
        "DriverName": "postgres",
        "DataSource": "postgres://mattermost:111222@postgres:5432/mmdb?sslmode=disable\u0026connect_timeout=10",
        "DataSourceReplicas": [],
        "MaxIdleConns": 20,
        "ConnMaxIdleTimeMilliseconds": 300000,
        "MaxOpenConns": 300,
        "Trace": false,
        "AtRestEncryptKey": "o9j4gknys91e5b5eyyu4f4zayy71q8jw",
        "QueryTimeout": 30,
        "DisableDatabaseSearch": false,
        "ReplicaLagSettings": []
    "LogSettings": {
        "EnableConsole": true,
        "ConsoleLevel": "INFO",
        "ConsoleJson": true,
        "EnableColor": false,
        "EnableFile": true,
        "FileLevel": "INFO",
        "FileJson": true,
        "FileLocation": "",
        "EnableDiagnostics": true,
        "EnableSentry": true,
        "AdvancedLoggingConfig": ""
    "ExperimentalAuditSettings": {
        "FileEnabled": false,
        "FileName": "",
        "FileMaxSizeMB": 100,
        "FileMaxAgeDays": 0,
        "FileMaxBackups": 0,
        "FileCompress": false,
        "FileMaxQueueSize": 1000,
    "NotificationLogSettings": {
        "EnableFile": true,
        "FileJson": true,
        "FileLocation": "",
    "PasswordSettings": {
        "MinimumLength": 10,
        "Lowercase": true,
        "Number": true,
        "Uppercase": true,
        "Symbol": true
    "FileSettings": {
        "EnableMobileUpload": true,
        "EnableMobileDownload": true,
        "MaxFileSize": 104857600,
        "MaxImageResolution": 33177600,
        "DriverName": "local",
        "Directory": "./data/",
        "EnablePublicLink": false,
        "ExtractContent": true,
        "ArchiveRecursion": false,
        "PublicLinkSalt": "9z3rrz45pkk9i7r6xt63id5zaqq5sar9",
        "AmazonS3AccessKeyId": "",
        "AmazonS3Bucket": "",
        "AmazonS3PathPrefix": "",
        "AmazonS3Region": "",
        "AmazonS3SSL": true,
        "AmazonS3SignV2": false,
        "AmazonS3SSE": false,
        "AmazonS3Trace": false
    "EmailSettings": {
        "SendEmailNotifications": false,
        "FeedbackName": "",
        "FeedbackEmail": "",
        "ReplyToAddress": "",
        "FeedbackOrganization": "",
        "EnableSMTPAuth": false,
        "SMTPUsername": "",
        "SMTPPassword": "",
        "SMTPServer": "localhost",
        "SMTPPort": "10025",
        "SMTPServerTimeout": 10,
        "PushNotificationBuffer": 1000,
        "EnableEmailBatching": false,
        "EmailBatchingInterval": 30,
        "EnablePreviewModeBanner": true,
        "LoginButtonColor": "#0000",
    "RateLimitSettings": {
        "Enable": false,
        "PerSec": 10,
        "MaxBurst": 100,
        "MemoryStoreSize": 10000,
        "VaryByRemoteAddr": true,
        "VaryByUser": false,
        "VaryByHeader": ""
    "PrivacySettings": {
        "ShowEmailAddress": true,
        "ShowFullName": true
    "SupportSettings": {
        "TermsOfServiceLink": "https://mattermost.com/terms-of-service/",
        "PrivacyPolicyLink": "https://mattermost.com/privacy-policy/",
        "AboutLink": "https://about.mattermost.com/default-about/",
        "HelpLink": "https://about.mattermost.com/default-help/",
        "ReportAProblemLink": "https://about.mattermost.com/default-report-a-problem/",
        "SupportEmail": "",
        "CustomTermsOfServiceReAcceptancePeriod": 365,
        "EnableAskCommunityLink": true
    "AnnouncementSettings": {
        "EnableBanner": false,
        "BannerText": "",
        "BannerColor": "#f2a93b",
        "BannerTextColor": "#333333",
        "AllowBannerDismissal": true,
        "AdminNoticesEnabled": true,
        "UserNoticesEnabled": true,
        "NoticesURL": "https://notices.mattermost.com/",
        "NoticesFetchFrequency": 3600,
        "NoticesSkipCache": false
    "ThemeSettings": {
        "EnableThemeSelection": true,
        "DefaultTheme": "default",
        "AllowCustomThemes": true,
        "AllowedThemes": []
    "GitLabSettings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "",
        "AuthEndpoint": "",
        "TokenEndpoint": "",
        "UserAPIEndpoint": "",
        "DiscoveryEndpoint": "",
        "ButtonText": "",
        "ButtonColor": ""
    "GoogleSettings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "profile email",
        "UserAPIEndpoint": "https://people.googleapis.com/v1/people/me?personFields=names,emailAddresses,nicknames,metadata",
        "ButtonText": "",
        "ButtonColor": ""
    "Office365Settings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "User.Read",
        "UserAPIEndpoint": "https://graph.microsoft.com/v1.0/me",
        "DirectoryId": ""
    "OpenIdSettings": {
        "Enable": false,
        "Secret": "",
        "Id": "",
        "Scope": "profile openid email",
        "AuthEndpoint": "",
        "ButtonText": "",
        "ButtonColor": "#145DBF"
    "LdapSettings": {
        "Enable": false,
        "EnableSync": false,
        "LdapServer": "",
        "LdapPort": 389,
        "BaseDN": "",
        "BindUsername": "",
        "BindPassword": "",
        "UserFilter": "",
        "GroupFilter": "",
        "GuestFilter": "",
        "EnableAdminFilter": false,
        "AdminFilter": "",
        "GroupIdAttribute": "",
        "FirstNameAttribute": "",
        "LastNameAttribute": "",
        "EmailAttribute": "",
        "UsernameAttribute": "",
        "NicknameAttribute": "",
        "IdAttribute": "",
        "PositionAttribute": "",
        "LoginIdAttribute": "",
        "PictureAttribute": "",
        "SyncIntervalMinutes": 60,
        "PublicCertificateFile": "",
        "PrivateKeyFile": "",
        "QueryTimeout": 60,
        "MaxPageSize": 0,
        "LoginFieldName": "",
        "Trace": false
    "ComplianceSettings": {
        "Enable": false,
        "EnableDaily": false,
        "BatchSize": 30000
    "LocalizationSettings": {
        "DefaultServerLocale": "en",
        "DefaultClientLocale": "en",
        "AvailableLocales": ""
    "SamlSettings": {
        "Enable": false,
        "EnableSyncWithLdap": false,
        "IgnoreGuestsLdapSync": false,
        "Verify": true,
        "Encrypt": true,
        "SignRequest": false,
        "IdpURL": "",
        "IdpDescriptorURL": "",
        "IdpMetadataURL": "",
        "ServiceProviderIdentifier": "",
        "ScopingIDPProviderId": "",
        "ScopingIDPName": "",
        "IdpCertificateFile": "",
        "IdAttribute": "",
        "GuestAttribute": "",
        "AdminAttribute": "",
        "LocaleAttribute": "",
        "LoginButtonText": "SAML",
    "NativeAppSettings": {
        "AppCustomURLSchemes": [
            "mmauth://",
            "mmauthbeta://"
        "AppDownloadLink": "https://mattermost.com/download/#mattermostApps",
        "AndroidAppDownloadLink": "https://about.mattermost.com/mattermost-android-app/",
        "IosAppDownloadLink": "https://about.mattermost.com/mattermost-ios-app/"
    "ClusterSettings": {
        "Enable": false,
        "ClusterName": "",
        "OverrideHostname": "",
        "NetworkInterface": "",
        "BindAddress": "",
        "AdvertiseAddress": "",
        "UseIPAddress": true,
        "EnableGossipCompression": true,
        "EnableExperimentalGossipEncryption": false,
        "ReadOnlyConfig": true,
        "GossipPort": 8074,
        "StreamingPort": 8075,
        "MaxIdleConns": 100,
        "MaxIdleConnsPerHost": 128,
    "MetricsSettings": {
        "Enable": false,
        "BlockProfileRate": 0,
        "ListenAddress": ":8067"
    "ExperimentalSettings": {
        "EnableClickToReply": false,
        "RestrictSystemAdmin": false,
        "UseNewSAMLLibrary": false,
        "CloudUserLimit": 0,
        "CloudBilling": false,
        "EnableSharedChannels": false,
        "EnableRemoteClusterService": false
    "AnalyticsSettings": {
        "MaxUsersForStatistics": 2500
    "ElasticsearchSettings": {
        "ConnectionURL": "http://localhost:9200",
        "Username": "elastic",
        "Password": "changeme",
        "EnableIndexing": false,
        "EnableSearching": false,
        "EnableAutocomplete": false,
        "Sniff": true,
        "PostIndexReplicas": 1,
        "PostIndexShards": 1,
        "ChannelIndexReplicas": 1,
        "ChannelIndexShards": 1,
        "UserIndexReplicas": 1,
        "UserIndexShards": 1,
        "IndexPrefix": "",
        "LiveIndexingBatchSize": 1,
        "BulkIndexingTimeWindowSeconds": 3600,
        "RequestTimeoutSeconds": 30,
        "SkipTLSVerification": false,
        "Trace": ""
    "BleveSettings": {
        "IndexDir": "",
    "DataRetentionSettings": {
        "EnableFileDeletion": false,
        "MessageRetentionDays": 365,
        "FileRetentionDays": 365,
        "DeletionJobStartTime": "02:00",
        "BatchSize": 3000
    "MessageExportSettings": {
        "EnableExport": false,
        "ExportFormat": "actiance",
        "DailyRunTime": "01:00",
        "ExportFromTimestamp": 0,
        "BatchSize": 10000,
        "DownloadExportResults": false,
        "GlobalRelaySettings": {
            "CustomerType": "A9",
            "SMTPUsername": "",
            "SMTPPassword": "",
            "EmailAddress": "",
            "SMTPServerTimeout": 1800
    "JobSettings": {
        "RunJobs": true,
        "RunScheduler": true
    "PluginSettings": {
        "Enable": true,
        "EnableUploads": false,
        "AllowInsecureDownloadURL": false,
        "EnableHealthCheck": true,
        "Directory": "./plugins",
        "Plugins": {
            "com.mattermost.plugin-incident-management": {
                "BotUserID": "z5yd4cwcif867p847hqkzn9m4c"
        "PluginStates": {
            "com.mattermost.nps": {
                "Enable": true
                "Enable": true
        "EnableMarketplace": true,
        "MarketplaceURL": "https://api.integrations.mattermost.com",
        "SignaturePublicKeyFiles": [],
        "ChimeraOAuthProxyURL": ""
    "DisplaySettings": {
        "CustomURLSchemes": [],
        "ExperimentalTimezone": true
    "GuestAccountsSettings": {
        "Enable": false,
        "AllowEmailAccounts": true,
    "ImageProxySettings": {
        "Enable": false,
        "ImageProxyType": "local",
        "RemoteImageProxyURL": "",
        "RemoteImageProxyOptions": ""
    "CloudSettings": {
        "CWSURL": "https://customers.mattermost.com",
        "CWSAPIURL": "https://portal.internal.prod.cloud.mattermost.com"
    "ImportSettings": {
        "Directory": "./import",
        "RetentionDays": 30
    "ExportSettings": {
        "Directory": "./export",
        "RetentionDays": 30
Running docker-compose up -d starts the mattermost and postgres containers correctly. I define the mattermost user/email/password, create a team and go to the mattermost main page in the team that was newly created.
The problem is that I can’t add channels (as shown in the screenshot), even tough I’m admin.
I posted an answer here with a simple docker-compose demo to simulate the issue, but it went to moderation (Update: it’s not being moderated anymore, it’s the post above).
In any case, I faced that problem with the mattermost/mattermost-team-edition docker image release-6.0. I changed to release-5.39 and it works now (I can create a channel), so I will use release-5.39 for now.
It seems like a bug tough (at least regarding the docker image).
I don’t know if there is a more recent version, but at least in the official team edition images, the last release is 6.0:
https://hub.docker.com/r/mattermost/mattermost-team-edition/tags?page=1&ordering=last_updated&name=release
Update
I also can’t send emails in version release-6.0, but I can in version release-5.39 (with the same email settings). It seems the release-6.0 docker image is bugged :confused:
@lucasbasquerotto apologies for the confusion. 6.0 is not yet officially released (this is a release shipping on Oct 13). Not sure why it is showing up as the latest release, but we’ll get that cleaned up.
In the meantime, are you open to downloading release-5.39. This is our latest official release for both Team and Enterprise Edition: Docker Hub
EDIT: I just re-read your latest message and you noted you already downloaded 5.39 with the issue resolved :pray:
We’ll get our DockerHub release pages cleaned up so that it’s more obvious what is the latest release. Sorry for any inconvenience, and stay tuned for 6.0 release on Oct 13. :slight_smile:
Oh, that explains the issue I’m having! I saw it tagged as release on Dockerhub so I thought it was already released.Thanks!
