Hi Amy,
Not really helpful since i do not use docker. I did checked documentation, yet it does not make specific statements.
So after a few trials, I managed to upgrade to latest release, managed to have the instance back online, with a few downsides.
- the channels and teams are not recognised at login
- they are still in the DB and the only issue mattermost does not call them.
- when I made connection to local IP, it worked better
- when connecting from nginx proxy, they do not show up.
I get this repetitively in console:
warn [2022-10-27 15:32:33.483 +02:00] Error while populating webconn config caller="api4/websocket.go:58" id=undefined error="invalid connection id: undefined"
error [2022-10-27 15:32:33.761 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=u351q3fddfgiukt5tj3c7mh7aw ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.761 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=acqcfifhrffxjdm77d9eacjqcr ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.798 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=4k67spbfhifzdro7chk95untie ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.807 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=jwzj8saye7dgddop98y8r87p1e ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.859 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=a373qa6e57n9pek93fu8xamkyo ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.860 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=8aj1ie18rjdntk4apf7jdb6fha ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.920 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=9d4hhcuekinhjxd4b9yf8ca7uw ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
error [2022-10-27 15:32:33.920 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=geg6pe7zgtd47pij18599fs9ao ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
Any ideas to what could cause this?
Adding here DEBUG logs:
warn [2022-10-27 15:44:42.487 +02:00] Unrecognized config permissions tag value. caller="api4/config.go:431" tag_value="sysconsole_write_*_read"
debug [2022-10-27 15:44:42.493 +02:00] Email batching job starting. Checking for pending emails periodically. caller="email/email_batching.go:89" interval_in_seconds=30
debug [2022-10-27 15:44:42.493 +02:00] Next run time for scheduler caller="jobs/schedulers.go:147" scheduler_name=migrations next_runtime="<nil>"
debug [2022-10-27 15:44:42.493 +02:00] Scheduler: isEnabled: false caller="last_accessible_post/scheduler.go:20" scheduler=last_accessible_post
debug [2022-10-27 15:44:42.493 +02:00] Scheduler: isEnabled: false caller="notify_admin/scheduler.go:20" scheduler=upgrade_notify_admin
debug [2022-10-27 15:44:42.495 +02:00] Not auto installing/upgrade because plugin was disabled caller="app/plugin.go:1021" plugin_id=com.mattermost.calls version=
debug [2022-10-27 15:44:42.498 +02:00] Next run time for scheduler caller="jobs/schedulers.go:147" scheduler_name=plugins next_runtime="2022-10-28 15:44:42.498385953 +0200 CEST m=+88985.262649098"
debug [2022-10-27 15:44:42.499 +02:00] Next run time for scheduler caller="jobs/schedulers.go:147" scheduler_name=export_delete next_runtime="2022-10-28 15:44:42.499318336 +0200 CEST m=+88985.263581484"
debug [2022-10-27 15:44:42.511 +02:00] Next run time for scheduler caller="jobs/schedulers.go:147" scheduler_name=product_notices next_runtime="2022-10-27 16:44:42.51195766 +0200 CEST m=+6185.276220807"
debug [2022-10-27 15:44:42.512 +02:00] Next run time for scheduler caller="jobs/schedulers.go:147" scheduler_name=import_delete next_runtime="2022-10-28 15:44:42.512934751 +0200 CEST m=+88985.277197897"
info [2022-10-27 15:44:42.512 +02:00] 2022/10/27 15:44:42 LoadPluginConfiguration API failed to unmarshal: json: cannot unmarshal string into Go struct field CustomAttribute.CustomAttributes.GroupIDs of type []string
caller="io/io.go:428" plugin_id=com.mattermost.custom-attributes source=plugin_stderr
debug [2022-10-27 15:44:42.512 +02:00] Scheduler: isEnabled: false caller="notify_admin/scheduler.go:20" scheduler=trial_notify_admin
info [2022-10-27 15:44:42.514 +02:00] 2022/10/27 15:44:42 LoadPluginConfiguration API failed to unmarshal: json: cannot unmarshal bool into Go struct field Configuration.EnableCodePreview of type string
caller="io/io.go:428" plugin_id=github source=plugin_stderr
debug [2022-10-27 15:44:42.519 +02:00] failed to fetch license twice. May incorrectly default to on-prem mode caller="app/plugin_api.go:968" plugin_id=com.mattermost.apps
debug [2022-10-27 15:44:42.519 +02:00] available upstream caller="app/plugin_api.go:968" plugin_id=com.mattermost.apps type=HTTP
debug [2022-10-27 15:44:42.519 +02:00] Skipped upstream: AWS Lambda: not configured. caller="app/plugin_api.go:968" plugin_id=com.mattermost.apps error="AWS credentials are not set: not found"
debug [2022-10-27 15:44:42.519 +02:00] available upstream caller="app/plugin_api.go:968" plugin_id=com.mattermost.apps type="Mattermost Plugin"
debug [2022-10-27 15:44:42.519 +02:00] Skipped upstream: OpenFaaS: not configured. caller="app/plugin_api.go:968" plugin_id=com.mattermost.apps error="OPENFAAS_URL environment variable must be defined: not found"
debug [2022-10-27 15:44:42.569 +02:00] Received HTTP request caller="web/handlers.go:165" method=PUT url=/api/v4/config request_id=89pj9ipsqbrqt8p75p6gs7n4ew status_code=200
warn [2022-10-27 15:44:42.668 +02:00] Error while populating webconn config caller="api4/websocket.go:58" id=undefined error="invalid connection id: undefined"
debug [2022-10-27 15:44:42.668 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/websocket request_id=nkyohn6ayind7n1hjxeknfodkw
debug [2022-10-27 15:44:42.812 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/posts/ghism4id9pbi5q8h35yxn867xw/thread request_id=py343sb1mbyazf8azc1bj5yggo status_code=304
error [2022-10-27 15:44:42.821 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=tq6bmsyym7ryjf7wyis4igpa7c ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.821 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=tq6bmsyym7ryjf7wyis4igpa7c status_code=500
error [2022-10-27 15:44:42.821 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=uuzeha9h3irj3rc48aa38erexc ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.821 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=uuzeha9h3irj3rc48aa38erexc status_code=500
debug [2022-10-27 15:44:42.824 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/channels/7gkkgstwhbbj9knia55apw9seo/posts request_id=3jtnxzqyzjbkigrudjkd1f97kh status_code=200
debug [2022-10-27 15:44:42.824 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/plugins/webapp request_id=bta6rn83h7gb8fmog3wozqqn1r status_code=200
debug [2022-10-27 15:44:42.825 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/unread request_id=qmsqrpf9hpdf9ggebwis3c9zgy status_code=200
debug [2022-10-27 15:44:42.858 +02:00] Received HTTP request caller="web/handlers.go:165" method=POST url=/api/v4/users/ids request_id=jya3dd5a63n97frqu13drin7fw status_code=200
debug [2022-10-27 15:44:42.888 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/plugins/webapp request_id=xa9bxz9iwf8eirk5s7cddpmbpw status_code=200
debug [2022-10-27 15:44:42.889 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/channels/7gkkgstwhbbj9knia55apw9seo/posts request_id=wu883m5njbgc5qbzwhtaogughe status_code=200
error [2022-10-27 15:44:42.890 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=ozsbt9jawffs781b99qwmuiexa ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.890 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=ozsbt9jawffs781b99qwmuiexa status_code=500
error [2022-10-27 15:44:42.890 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=z31ju7zthf83tbxqbja5z9ycbc ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.890 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=z31ju7zthf83tbxqbja5z9ycbc status_code=500
debug [2022-10-27 15:44:42.891 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/unread request_id=9a4zdb6m1irzzg1iwt8ar9ny6y status_code=200
debug [2022-10-27 15:44:42.924 +02:00] Received HTTP request caller="web/handlers.go:165" method=POST url=/api/v4/users/ids request_id=j7x6qwtnqinrjx87e585d1kjaw status_code=200
error [2022-10-27 15:44:42.943 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=w5tde64thfyujkz8upoyhwggpc ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.943 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=w5tde64thfyujkz8upoyhwggpc status_code=500
debug [2022-10-27 15:44:42.950 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/channels/7gkkgstwhbbj9knia55apw9seo/posts request_id=3w8k19gp4jrtdr76tzmhskgq6h status_code=200
error [2022-10-27 15:44:42.951 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=ejs87x99utraimp874zz4wuqdc ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:42.951 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=ejs87x99utraimp874zz4wuqdc status_code=500
debug [2022-10-27 15:44:42.954 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/plugins/webapp request_id=7upg96y6n38rupszbsxuzneemy status_code=200
debug [2022-10-27 15:44:42.954 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/unread request_id=633c96e4y3ghinzm5ps5azuh7c status_code=200
debug [2022-10-27 15:44:42.983 +02:00] Received HTTP request caller="web/handlers.go:165" method=POST url=/api/v4/users/ids request_id=o3dxpyeygib37yc371m9rjht5y status_code=200
error [2022-10-27 15:44:43.002 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=yshotnite3g17dy48xt87di57o ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:43.002 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=yshotnite3g17dy48xt87di57o status_code=500
error [2022-10-27 15:44:43.005 +02:00] Unable to get the channel members. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=x8ij4b6txfyppq8zyspmxu6sxw ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelMembersForUser http_code=500 error="GetChannelMembersForUser: Nu s-au putut obține membrii canalului., failed to find ChannelMembers data with teamId=nkpmw153s7gd8n9gksissstkea and userId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 12, name "MsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:43.005 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels/members request_id=x8ij4b6txfyppq8zyspmxu6sxw status_code=500
debug [2022-10-27 15:44:43.015 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/plugins/webapp request_id=di83gxdzcbbt5mogosw77spyso status_code=200
debug [2022-10-27 15:44:43.015 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/channels/7gkkgstwhbbj9knia55apw9seo/posts request_id=5z6xacwbfibz5r75f6rcc7bkdy status_code=200
debug [2022-10-27 15:44:43.015 +02:00] Denied due to throttling settings code=429 caller="app/ratelimit.go:88" key=18k3yzjshpr83chtiuna4kon5a
debug [2022-10-27 15:44:43.033 +02:00] Denied due to throttling settings code=429 caller="app/ratelimit.go:88" key=18k3yzjshpr83chtiuna4kon5a
debug [2022-10-27 15:44:43.045 +02:00] Denied due to throttling settings code=429 caller="app/ratelimit.go:88" key=18k3yzjshpr83chtiuna4kon5a
error [2022-10-27 15:44:43.051 +02:00] Unable to get the channels. caller="web/context.go:117" path=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=tx937c6tc7rxdejnxkhmzct1jr ip_addr=172.17.88.2 user_id=48bbj6nc97f55npw6br7gxo96h method=GET err_where=GetChannelsForUser http_code=500 error="GetChannelsForUser: Nu pot obține canalele., failed to get channels with TeamId=nkpmw153s7gd8n9gksissstkea and UserId=48bbj6nc97f55npw6br7gxo96h: sql: Scan error on column index 17, name "TotalMsgCountRoot": converting NULL to int64 is unsupported"
debug [2022-10-27 15:44:43.051 +02:00] Received HTTP request caller="web/handlers.go:165" method=GET url=/api/v4/users/me/teams/nkpmw153s7gd8n9gksissstkea/channels request_id=tx937c6tc7rxdejnxkhmzct1jr status_code=500
debug [2022-10-27 15:44:43.059 +02:00] Denied due to throttling settings code=429 caller="app/ratelimit.go:88" key=18k3yzjshpr83chtiuna4kon5a
debug [2022-10-27 15:44:43.063 +02:00] Denied due to throttling settings code=429
