Click on Draw button and be able to draw
Nothing happens! And that is weird…
No logs related to the plugin on:
journalctl -f -u mattermost
tail -f /opt/mattermost/logs/mattermost.log
I observed that after using draw button (and nothing happens) I get an error on the GUI, on integrations and custom emojis: An error occurred in the com.mattermost.draw-plugin plugin.
I was unable to install the plugin in version 0.0.4 into my 7.10 demo system, not sure if this is still supposed to work on newer setups, it didn’t receive updates for quite some time and there were some breaking changes I think for plugins in one of the last few releases.
Also trying to compile the code which seems to also have a preview of the 0.0.5 version does not work here, getting the following errors:
npm WARN tarball tarball data for redux-offline@git+ssh://git@github.com/enahum/redux-offline.git#885024de96b6ec73650c340c8928066585c413df (sha512-srmJ1vWm8ZQTYflZCf7oUs3WBX83GyCIzsFUpwxUg2wcDHngSHjjShRTCgmkciPkVmM4aJ33i9baYS9jRC+zLA==) seems to be corrupted. Trying again.
npm ERR! code EINTEGRITY
npm ERR! sha512-srmJ1vWm8ZQTYflZCf7oUs3WBX83GyCIzsFUpwxUg2wcDHngSHjjShRTCgmkciPk VmM4aJ33i9baYS9jRC+zLA== integrity checksum failed when using sha512: wanted sha 512-srmJ1vWm8ZQTYflZCf7oUs3WBX83GyCIzsFUpwxUg2wcDHngSHjjShRTCgmkciPkVmM4aJ33i9ba YS9jRC+zLA== but got sha512-SThdHzd9uoZ4Uo6I1X4fc1Q1aU5erk6TRZdRVdRtkHrIaYzVhcNq ZYGg/euh+LVfiAWQIo6WPeKuGgrZVghBSw==. (49960 bytes)
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2023-05-22T05_02_04_603Z-debug.log
make: *** [Makefile:79: webapp/node_modules] Error 1
@jespino since this seems to be “your” plugin: Any ideas?
That’s likely, although I haven’t tested the message queue plugin with a recent installation, unfortunately there are no release binaries and I’m unable to build it to test it:
