Plugins not loading
Hi everybody,
i made a fresh install of Mattermost 5.33 on Ubuntu 20.04 LTS but a cannot load plugins i think due to the /plugins and /client/plugins “permission denied” issue.
Can you please help me to solve this problem?
I searched on the forum but i didn’t find a solution.
Here the error log:
{"level":"error","ts":1617894859.7185578,"caller":"app/plugin.go:288","msg":"Failed to sync plugin from file store","bundle":"plugins/com.mattermost.webex.tar.gz","error":"installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists"}
{"level":"error","ts":1617894864.1574545,"caller":"app/plugin.go:843","msg":"Failed to install prepackaged plugin","path":"/opt/mattermost/prepackaged_plugins/mattermost-plugin-channel-export-v0.2.2-linux-amd64.tar.gz","error":"Failed to install extracted prepackaged plugin /opt/mattermost/prepackaged_plugins/mattermost-plugin-channel-export-v0.2.2-linux-amd64.tar.gz: installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists","errorVerbose":"installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists\nFailed to install extracted prepackaged plugin /opt/mattermost/prepackaged_plugins/mattermost-plugin-channel-export-v0.2.2-linux-amd64.tar.gz\ngithub.com/mattermost/mattermost-server/v5/app.(*App).processPrepackagedPlugin\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:895\ngithub.com/mattermost/mattermost-server/v5/app.(*App).processPrepackagedPlugins.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:841\nruntime.goexit\n\truntime/asm_amd64.s:1374"}
{"level":"error","ts":1617894864.7765427,"caller":"app/plugin.go:843","msg":"Failed to install prepackaged plugin","path":"/opt/mattermost/prepackaged_plugins/mattermost-plugin-nps-v1.1.0-linux-amd64.tar.gz","error":"Failed to install extracted prepackaged plugin /opt/mattermost/prepackaged_plugins/mattermost-plugin-nps-v1.1.0-linux-amd64.tar.gz: installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists","errorVerbose":"installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., destination already exists\nFailed to install extracted prepackaged plugin /opt/mattermost/prepackaged_plugins/mattermost-plugin-nps-v1.1.0-linux-amd64.tar.gz\ngithub.com/mattermost/mattermost-server/v5/app.(*App).processPrepackagedPlugin\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:895\ngithub.com/mattermost/mattermost-server/v5/app.(*App).processPrepackagedPlugins.func2\n\tgithub.com/mattermost/mattermost-server/v5/app/plugin.go:841\nruntime.goexit\n\truntime/asm_amd64.s:1374"}
thanks
Regards
Massimo
Hello! Can you confirm that your files are owned by the Mattermost user and Mattermost group in the /opt/mattermost directory, as well as in all subfolders and files?
These are the permissions on /opt/mattermost:
administrator@mattermost:~$ ls -l /opt/mattermost
total 284
drwxrwxr-x 2 mattermost mattermost 4096 Mar 31 12:56 bin
drwxrwxr-x 7 mattermost mattermost 4096 Apr 7 13:26 client
drwxrwxr-x 3 mattermost mattermost 4096 Apr 8 11:22 config
drwxrwxr-x 6 mattermost mattermost 4096 Apr 8 16:51 data
-rw-rw-r-- 1 mattermost mattermost 2052 Mar 31 12:55 ENTERPRISE-EDITION-LICENSE.txt
drwxrwxr-x 2 mattermost mattermost 4096 Mar 31 12:55 fonts
drwxrwxr-x 2 mattermost mattermost 4096 Apr 8 08:48 i18n
drwxrwxr-x 2 mattermost mattermost 4096 Apr 7 15:14 logs
-rw-rw-r-- 1 mattermost mattermost 903 Mar 31 12:55 manifest.txt
-rw-rw-r-- 1 mattermost mattermost 230476 Mar 31 12:55 NOTICE.txt
drwxr–r-- 5 mattermost mattermost 4096 Apr 8 16:52 plugins
drwxrwxr-x 2 mattermost mattermost 4096 Mar 31 12:56 prepackaged_plugins
-rw-rw-r-- 1 mattermost mattermost 6397 Mar 31 12:55 README.md
drwxrwxr-x 2 mattermost mattermost 4096 Mar 31 12:55 templates
These are the permissions on /opt/mattermost/plugins/
administrator@mattermost:~$ ls -l /opt/mattermost/plugins/
ls: cannot access ‘/opt/mattermost/plugins/com.mattermost.plugin-channel-export’: Permission denied
ls: cannot access ‘/opt/mattermost/plugins/com.mattermost.nps’: Permission denied
ls: cannot access ‘/opt/mattermost/plugins/com.mattermost.webex’: Permission denied
total 0
d??? ? ? ? ? ? com.mattermost.nps
d??? ? ? ? ? ? com.mattermost.plugin-channel-export
d??? ? ? ? ? ? com.mattermost.webex
Thanks
Massimo
Hello, @Massimo
Can you please run the following command first and then observe if you are still facing the same issue when you are attempting to load the plugins?
Run the tail -f /opt/mattermost/log/mattermost.log command to observe while you attempt to reproduce the issue again after you run the command above.
Hi @ahmaddanial ,
the command seems to have solved the issue, now the plugins are activated and working.
Thanks for your help.
Regards
Massimo
Hi, @Massimo
You are most welcome. Happy to help!
