Plugin installation fail
Hello I use mattermost 7.7.0 team edition deployed with this char helm mattermost-helm/charts/mattermost-enterprise-edition at master · mattermost/mattermost-helm · GitHub
The plugin installation fail
Activate plugins
plugin are installed and available in the app
plugin installation failed. There is an example of plugin installation faillure
{"timestamp":"2023-04-14 07:09:37.199 Z","level":"error","msg":"Failed to install prepackaged plugin","caller":"app/plugin.go:967","path":"/mattermost/prepackaged_plugins/mattermost-plugin-nps-v1.3.1-linux-amd64.tar.gz","error":"Failed to install extracted prepackaged plugin /mattermost/prepackaged_plugins/mattermost-plugin-nps-v1.3.1-linux-amd64.tar.gz: installExtractedPlugin: Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name., mkdir plugins/com.mattermost.nps: permission denied"}
I think this is “normal” because the chart make the volume “plugin” be mounted on the container in the mattermost/client/plugins and the plugin try to be installed in the mattermost/plugin folder where no volume is mounted. Did I miss something ?
Hi @360 ,
I think this is related to your previous topic, so I’m linking them here:
I’m unable to help you with this issue, because I do not use K8S, but I’ll see if I can find someone who’s able to help.
Hello @agriesser
Any news ? I still encouter this problem issue in 7.9.3 and plugins are important functionalities for my company
Hi @360 ,
as I said, I’m not using Kubernetes here, so I don’t have a solution or workaround, but please have a look here, this user posted a workaround that might also help you:
Thank you for your answer. It looks like other users has exactly the same right problem than me that cause plugin installation faillure. I tested the workaround posted by this user but my init container has no right to change the right on the folder /client/plugins “operation not permitted”
Could you maybe ask in the other thread? I’ve no test environment for that and cannot help with that issue, sorry.
