Description
When downloading the dump file from the Mattermost Metrics Plugin and importing it into Prometheus by mounting it as the TSDB data directory, no Mattermost-specific metrics are visible in the metrics explorer. Only the 5 default Prometheus internal scrape metadata metrics are present:
- scrape_duration_seconds
- scrape_samples_post_metric_relabeling
- scrape_samples_scraped
- scrape_series_added
- up
No mattermost_* or go_* metrics are present in the imported data.
- Install and enable the Mattermost Metrics Plugin on a Mattermost Entry Edition instance hosted by Mattermost
- Navigate to the plugin settings and download the dump file
- Decompress the downloaded archive
- Mount the extracted directory as Prometheus TSDB data volume in docker-compose.yml:
volumes:- /path/to/extracted/dump:/prometheus/data
- Start Prometheus and open the metrics explorer
- Observe that only 5 Prometheus-internal scrape metrics are available and no mattermost_* metrics appear
After importing the dump file into Prometheus, all collected Mattermost metrics should be visible and queryable in the metrics explorer, including but not limited to:
- mattermost_api_time
- mattermost_http_requests_total
- mattermost_db_store_time
- mattermost_post_total
- mattermost_websocket_broadcasts_total
- Standard Go runtime metrics (go_goroutines, go_memstats_alloc_bytes, etc.)
Mattermost Server Version : 10.11.19
Refer GitHub Issues : Dump file downloaded from Metrics Plugin does not contain Mattermost metrics and only Prometheus scrape metadata visible after import · Issue #45 · mattermost/mattermost-plugin-metrics · GitHub
