Err_Connection_Refused()-102 after update mattermost v5.31, what to do?
File: api.file.read_file.reading_local.app_error, open data/20180124/teams/noteam/channels/mbx9szdexb8nue66g79q47f7
po/users/kqo9h514h7f9jqr35nwuht16sw/tucyx179stym58rni5r4asingo/20180123_135221.jpg: no such file or directory"}
{“level”:“error”,“ts”:1612257353.4884248,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
File: api.file.read_file.reading_local.app_error, open data/20180216/teams/noteam/channels/mbx9szdexb8nue66g79q47f7
po/users/1gezjtzy3jd3u8rsyaa71wftme/u1hjioemkib38b8r5hab96baxr/image-94aa0627-99d7-4575-b81d-d8cb7974e2f1.jpg: no s
uch file or directory”}
{“level”:“error”,“ts”:1612257353.491159,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“ReadF
ile: api.file.read_file.reading_local.app_error, open data/20180215/teams/noteam/channels/mbx9szdexb8nue66g79q47f7p
o/users/1gezjtzy3jd3u8rsyaa71wftme/hxrickcco7f8mmu8a7yycc7aia/Screenshot_20180215-125110.png: no such file or direc
tory”}
{“level”:“error”,“ts”:1612257353.4923196,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
File: api.file.read_file.reading_local.app_error, open data/20180207/teams/noteam/channels/mbx9szdexb8nue66g79q47f7
po/users/w63dpm7qdjyafxbmsgoycs51co/xcepdtmse7f45gbg13j79x5bsc/IMG_20180207_181545.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.492386,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“ReadF
ile: api.file.read_file.reading_local.app_error, open data/20180207/teams/noteam/channels/mbx9szdexb8nue66g79q47f7p
o/users/w63dpm7qdjyafxbmsgoycs51co/hb99yta3cpf93czfj9nafozrta/IMG_20180207_181528.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.4924304,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/w63dpm7qdjyafxbmsgoycs51co/8fw6wji8ot8eieqhhfgtff4wuc/IMG_20180207_181705.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.492471,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“ReadF
o/users/w63dpm7qdjyafxbmsgoycs51co/7u93u8u73bdxjk8fq6rhhmy1ey/IMG_20180207_181554.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.502896,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“ReadF
ile: api.file.read_file.reading_local.app_error, open data/20180123/teams/noteam/channels/mbx9szdexb8nue66g79q47f7p
o/users/w63dpm7qdjyafxbmsgoycs51co/teutrugxg7rdiqnmfxrj7usbsh/IMG_20180122_130134.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5029635,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
File: api.file.read_file.reading_local.app_error, open data/20180123/teams/noteam/channels/mbx9szdexb8nue66g79q47f7
po/users/w63dpm7qdjyafxbmsgoycs51co/7b1cz7uh8b8k7maj41rqdm5zso/IMG_20180122_131320.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5030026,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/w63dpm7qdjyafxbmsgoycs51co/h1j1uaywzfdxxdiraxk8o3jr9r/IMG_20180122_124738.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5030427,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/w63dpm7qdjyafxbmsgoycs51co/summm1y5a7g97fkmbxhj1d6qyh/IMG_20180122_124737.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5030806,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/w63dpm7qdjyafxbmsgoycs51co/re1eohgb8jbpmjt61signsxf9a/IMG_20180122_130301.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5250473,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
File: api.file.read_file.reading_local.app_error, open data/20180215/teams/noteam/channels/mbx9szdexb8nue66g79q47f7
po/users/1gezjtzy3jd3u8rsyaa71wftme/u3jpriiw6jbobk3txs78bcg95y/FB_IMG_1518622673619.jpg: no such file or directory”
{“level”:“error”,“ts”:1612257353.52624,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“ReadFi
le: api.file.read_file.reading_local.app_error, open data/20180124/teams/noteam/channels/mbx9szdexb8nue66g79q47f7po
/users/kqo9h514h7f9jqr35nwuht16sw/qx5hi4hrkfbi9cic7b515yn76o/20180123_123544.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5262926,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/kqo9h514h7f9jqr35nwuht16sw/hmi97s8hdfr1jp73dp913pghcr/20180123_123658.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5263345,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:“Read
po/users/kqo9h514h7f9jqr35nwuht16sw/k1ha5uke4pggbp8eys8tuerd3a/20180123_123644.jpg: no such file or directory”}
{“level”:“error”,“ts”:1612257353.5272975,“caller”:“app/file.go:1045”,“msg”:“error reading image file”,“error”:"Read
after the matermost is turned off
works only through the command / opt / mattermost / bin / platform.
if I close the mattermost stops working
Hello, @raimbekov
I want to understand if you have configured Mattermost to run as a service via mattermost.service file typically located in /lib/systemd/system directory. For example:
[Unit]
Description=Mattermost
After=network.target
After=postgresql.service
BindsTo=postgresql.service
[Service]
Type=notify
ExecStart=/opt/mattermost/bin/mattermost
TimeoutStartSec=3600
Restart=always
RestartSec=10
User=mattermost
Group=mattermost
LimitNOFILE=49152
[Install]
If you have configured it correctly, loaded it into the daemon, and start the service via sudo systemctl start mattermost.service, you should be able to have Mattermost running without having the terminal / CLI window open.
