Export data for external reference (i.e. to HTML or PDF)?
Is there a way to export a channel to something that can be used offline, such as to an HTML file or perhaps as a PDF file?
The only export functionality I can find is to a json file for importing into another server.
Maybe you could write a bot for that.
Get a list with all posts from a channel. Get Posts.
Than read each post with Get Post If there are files included you can get them with Get File.
Your bot can write it to HTML or PDF.
Kind regards,
Tom
