Hi folks,
I was just trying to export my permission scheme as documented here: Command line tools — Mattermost documentation.
I’m running Mattermost 7.8.5.
Unfortunately though, this command seems to be gone:
root@HOSTNAME /opt/mattermost # sudo -u mattermost ./bin/mattermost permissions export
Error: unknown command "permissions" for "mattermost"
Run 'mattermost --help' for usage
That being said, historically, a lot of commands moved to mmctl, but unfortunately this command doesn’t seem to have been migrated:
root@HOSTNAME /opt/mattermost # mmctl permissions
Management of permissions
Usage:
mmctl permissions [command]
Available Commands:
add Add permissions to a role (EE Only)
remove Remove permissions from a role (EE Only)
reset Reset default permissions for role (EE Only)
role Management of roles
Is there currently any way to export permission schemes in a structured way?
Cheers & Thanks for any hint
Thomas
