As many other in this forum, Im facing a issue with the websocket connection.
{"timestamp":"2023-11-26 12:40:28.516 Z","level":"debug","msg":"Failed to upgrade websocket connection.","caller":"web/context.go:111","path":"/api/v4/websocket","request_id":"bxwqri3wein5xq6wuh7ufmxpkh","ip_addr":"127.0.0.1","user_id":"dxzqbhra3bbuubf53cy35r8j3o","method":"GET","err_where":"connect","http_code":400,"error":"connect: Failed to upgrade websocket connection., websocket: request origin not allowed by Upgrader.CheckOrigin"}
Install Mattermost with the omnibus method.
sudo MMO_HTTPS=false apt install mattermost-omnibus
In other server install Caddy as a reverse proxy.
chat.troco.io {
encode gzip
reverse_proxy 192.168.10.108:8065
log {
output file /var/log/caddy/troco.io/mattermostCaddy.log {
roll_size 500mb
Go to chat.troco.io
Open web inspector, see websocket connection fail with 403
Go to mattermost logs and see the error
Websocket should work even if its proxied.
Or at least should be possible to change that Upgrader.CheckOrigin setting
Websocket fails to connect.
