My company is testing mattermost but I have trouble with websocket.
The error is well known :
[2017/05/15 17:53:25 CEST] [EROR] /api/v3/users/websocket:connect code=500 rid=u877fuhbmifg9btbcg3ca199xr uid=wgnz56hijffzmf4uw19qkymsno ip=192.44.77.211, 10.0.4.107 Failed to upgrade websocket connection [details: ]
I have read many documents about this error, but I didn’t find any solution.
My config is :
- Mattermost 3.8.2 on debian 8
- MariaDB
- Nginx 1.12
Here is my nginx conf.
upstream mattermost {
server 127.0.0.1:8065;
server {
listen *:80;
server_name mattermost.example.net;
client_max_body_size 50M;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
proxy_read_timeout 600s;
proxy_pass http://mattermost;
location / {
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
Can I have any help ?
Thanks.
Eric
