Initially when I set up Mattermost on Debian, I used the default nginx configuration file that was shown in the production install instructions:
server {
server_name mattermost.example.com;
location / {
client_max_body_size 50M;
proxy_pass http://localhost:8065;
However, when I reloaded nginx I started getting 400 errors from the websocket requests:
[19/Oct/2015:12:54:26 +0000] "GET /api/v1/websocket HTTP/1.1" 400 161 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
and seeing this message when I connected to the service:
We cannot reach the Mattermost service. The service may be down or misconfigured. Please contact an administrator to make sure the WebSocket port is configured properly.
I found the following post: Setup behind nginx - #6 by pbruna that suggests a slightly different nginx configuration which I followed to create this:
server {
listen 80;
server_name mattermost.<domain>;
location / {
# websocket support
proxy_http_version 1.1;
location /api/v1/websocket {
keepalive_timeout 10;
now I am not getting 400s but 101s instead:
[19/Oct/2015:14:38:31 +0000] "GET /api/v1/websocket HTTP/1.1" 101 12 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
and still on the channel that I have created the following message shows:
Any thoughts on what could be going on here?
