■Environment in development
The configuration of the server that we are currently building is as follows.
【User Computer】 -https- 【Load balancer】-http- 【Nginx server】-http- 【Mattermost server】 -http- 【Database server】
■Current Issues
If you check in the developer tools of chrome, you will see the following.
How do I configure Nginx to work properly?
■configuration file
filename:/etc/nginx/conf.d/mattermost
upstream backend {
server [Mattermost server IP]:8065;
keepalive 32;
server {
listen 80;
server_name [Mattermost server FQDN];
proxy_http_version 1.1;
client_max_body_size 50M;
proxy_set_header Host $host;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_body_timeout 60;
send_timeout 300;
lingering_timeout 5;
proxy_connect_timeout 90;
proxy_send_timeout 300;
proxy_read_timeout 90s;
proxy_pass http://backend;
location / {
proxy_read_timeout 600s;
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_lock on;
/opt/mattermost/config/config.json
"ServiceSettings": {
"SiteURL": "https://[mattermost server FQDN]",
"WebsocketURL": "",
"LicenseFileLocation": "",
"ListenAddress": ":8065",
"ConnectionSecurity": "",
"TLSCertFile": "",
"TLSKeyFile": "",
"TLSMinVer": "1.2",
"TLSStrictTransport": false,
"TLSOverwriteCiphers": [],
"UseLetsEncrypt": false,
"Forward80To443": false,
"TrustedProxyIPHeader": [
"X-Forwarded-For",
"X-Real-Ip"
"ReadTimeout": 300,
"WriteTimeout": 300,
"IdleTimeout": 60,
"MaximumLoginAttempts": 10,
"EnableCommands": true,
"GoogleDeveloperKey": "",
"EnableOnlyAdminIntegrations": true,
"EnableLinkPreviews": true,
"RestrictLinkPreviews": "",
"EnableTesting": false,
"EnableDeveloper": false,
"EnableOpenTracing": false,
"AllowCorsFrom": "*",
"CorsExposedHeaders": "",
"CorsDebug": false,
"SessionLengthWebInDays": 30,
"SessionLengthSSOInDays": 1,
"SessionCacheInMinutes": 10,
"WebsocketSecurePort": 443,
"WebsocketPort": 80,
"WebserverMode": "gzip",
"EnableGifPicker": true,
"GfycatApiKey": "2_KtH_W5",
"GfycatApiSecret": "3wLVZPiswc3DnaiaFoLkDvB4X0IV6CpMkj4tf2inJRsBY6-FnkT08zGmppWFgeof",
"EnableCustomEmoji": true,
"EnableEmojiPicker": true,
"RestrictCustomEmojiCreation": "all",
"RestrictPostDelete": "all",
"AllowEditPost": "always",
"PostEditTimeLimit": -1,
"EnablePostSearch": true,
"EnableFileSearch": true,
"MinimumHashtagLength": 3,
"EnableUserStatuses": true,
"CloseUnusedDirectMessages": false,
"EnableTutorial": true,
"ExperimentalChannelOrganization": false,
"ImageProxyType": "",
"ImageProxyURL": "",
"ImageProxyOptions": "",
"EnableAPIUserDeletion": false,
"DisableLegacyMFA": true,
"EnableEmailInvitations": false,
"EnableSVGs": false,
"EnableLatex": false,
"EnableAPIChannelDeletion": false,
"EnableLocalMode": false,
"LocalModeSocketLocation": "/var/tmp/mattermost_local.socket",
"EnableAWSMetering": false,
"SplitKey": "",
"FeatureFlagSyncIntervalSeconds": 30,
"DebugSplit": false,
"ThreadAutoFollow": true,
"CollapsedThreads": "disabled",
"ManagedResourcePaths": "",
"EnableLegacySidebar": false,
"EnableReliableWebSockets": true
"TeamSettings": {
"SiteName": "mattermost",
"MaxUsersPerTeam": 10000,
"EnableTeamCreation": true,
"EnableUserCreation": true,
"EnableOpenServer": false,
"EnableCustomUserStatuses": true,
"EnableCustomBrand": false,
"CustomBrandText": "",
"CustomDescriptionText": "",
"RestrictTeamInvite": "all",
"RestrictPublicChannelManagement": "all",
"RestrictPrivateChannelManagement": "all",
"RestrictPublicChannelCreation": "all",
"RestrictPrivateChannelCreation": "all",
"RestrictPublicChannelDeletion": "all",
"RestrictPrivateChannelDeletion": "all",
"RestrictPrivateChannelManageMembers": "all",
"EnableXToLeaveChannelsFromLHS": false,
"UserStatusAwayTimeout": 300,
"MaxChannelsPerTeam": 2000,
"MaxNotificationsPerChannel": 1000000,
"EnableConfirmNotificationsToChannel": true,
"ExperimentalViewArchivedChannels": false,
"ExperimentalHideTownSquareinLHS": false,
"ExperimentalTownSquareIsReadOnly": false,
"LockTeammateNameDisplay": false,
"ClientRequirements": {
"AndroidLatestVersion": "",
"AndroidMinVersion": "",
"DesktopLatestVersion": "",
"DesktopMinVersion": "",
"IosLatestVersion": "",
"IosMinVersion": ""
"SqlSettings": {
"DriverName": "postgres",
"DataSource": "postgres://mmuser:[PW]@[DB serverIP]:5432/mattermost?sslmode=disable\u0026connect_timeout=10",
"DataSourceReplicas": [],
"MaxIdleConns": 20,
"ConnMaxIdleTimeMilliseconds": 300000,
"MaxOpenConns": 300,
"Trace": false,
"AtRestEncryptKey": "m8t37obsnpcud6jdkrzp5ficunieug91",
"QueryTimeout": 30,
"DisableDatabaseSearch": false,
"ReplicaLagSettings": []
"LogSettings": {
"EnableConsole": false,
"ConsoleLevel": "INFO",
"ConsoleJson": false,
"EnableColor": false,
"EnableFile": true,
"FileLevel": "INFO",
"FileJson": true,
"FileLocation": "",
"EnableDiagnostics": false,
"EnableSentry": true,
"AdvancedLoggingConfig": ""
"ExperimentalAuditSettings": {
"FileEnabled": false,
"FileName": "",
"FileMaxSizeMB": 100,
"FileMaxAgeDays": 0,
"FileMaxBackups": 0,
"FileCompress": false,
"FileMaxQueueSize": 1000,
"NotificationLogSettings": {
"EnableConsole": true,
"ConsoleJson": true,
"EnableFile": true,
"FileJson": true,
"FileLocation": "",
"PasswordSettings": {
"MinimumLength": 10,
"Lowercase": true,
"Number": true,
"Uppercase": true,
"Symbol": true
"FileSettings": {
"EnableMobileUpload": true,
"EnableMobileDownload": true,
"MaxFileSize": 10485760,
"DriverName": "local",
"Directory": "/opt/mattermost/data/",
"EnablePublicLink": false,
"ExtractContent": true,
"ArchiveRecursion": false,
"PublicLinkSalt": "c8m43np7r6wgauf3n4ng8y1ffphpnesf",
"AmazonS3AccessKeyId": "",
"AmazonS3Bucket": "",
"AmazonS3PathPrefix": "",
"AmazonS3Region": "",
"AmazonS3SSL": false,
"AmazonS3SignV2": false,
"AmazonS3SSE": false,
"AmazonS3Trace": false
"EmailSettings": {
"EnableSignUpWithEmail": false,
"SendEmailNotifications": false,
"FeedbackName": "",
"FeedbackEmail": "",
"ReplyToAddress": "",
"FeedbackOrganization": "",
"EnableSMTPAuth": false,
"SMTPUsername": "",
"SMTPPassword": "",
"SMTPServer": "150.26.199.247",
"SMTPPort": "25",
"SMTPServerTimeout": 10,
"PushNotificationBuffer": 1000,
"EnableEmailBatching": false,
"EmailBatchingInterval": 30,
"EnablePreviewModeBanner": true,
"LoginButtonColor": "#0000",
"RateLimitSettings": {
"Enable": false,
"PerSec": 10,
"MaxBurst": 100,
"MemoryStoreSize": 10000,
"VaryByRemoteAddr": true,
"VaryByUser": false,
"VaryByHeader": ""
"PrivacySettings": {
"ShowEmailAddress": false,
"ShowFullName": true
"SupportSettings": {
"TermsOfServiceLink": "https://mattermost.com/terms-of-service/",
"PrivacyPolicyLink": "",
"AboutLink": "",
"HelpLink": "",
"ReportAProblemLink": "",
"SupportEmail": "",
"CustomTermsOfServiceReAcceptancePeriod": 365,
"EnableAskCommunityLink": false
"AnnouncementSettings": {
"EnableBanner": false,
"BannerText": "",
"BannerColor": "#f2a93b",
"BannerTextColor": "#333333",
"AllowBannerDismissal": true,
"AdminNoticesEnabled": true,
"UserNoticesEnabled": false,
"NoticesURL": "https://notices.mattermost.com/",
"NoticesFetchFrequency": 3600,
"NoticesSkipCache": false
"ThemeSettings": {
"EnableThemeSelection": true,
"DefaultTheme": "default",
"AllowCustomThemes": true,
"AllowedThemes": []
"GitLabSettings": {
"Enable": true,
"Secret": "",
"Id": "",
"Scope": "",
"AuthEndpoint": "",
"TokenEndpoint": "",
"UserApiEndpoint": "",
"DiscoveryEndpoint": "",
"ButtonText": "",
"ButtonColor": ""
"GoogleSettings": {
"Enable": false,
"Secret": "",
"Id": "",
"Scope": "profile email",
"UserApiEndpoint": "https://people.googleapis.com/v1/people/me?personFields=names,emailAddresses,nicknames,metadata",
"ButtonText": "",
"ButtonColor": ""
"Office365Settings": {
"Enable": false,
"Secret": "",
"Id": "",
"Scope": "User.Read",
"UserApiEndpoint": "https://graph.microsoft.com/v1.0/me",
"DirectoryId": ""
"OpenIdSettings": {
"Enable": false,
"Secret": "",
"Id": "",
"Scope": "profile openid email",
"AuthEndpoint": "",
"ButtonText": "",
"ButtonColor": "#145DBF"
"LdapSettings": {
"Enable": false,
"EnableSync": false,
"LdapServer": "",
"LdapPort": 389,
"BaseDN": "",
"BindUsername": "",
"BindPassword": "",
"UserFilter": "",
"GroupFilter": "",
"GuestFilter": "",
"EnableAdminFilter": false,
"AdminFilter": "",
"GroupIdAttribute": "",
"FirstNameAttribute": "",
"LastNameAttribute": "",
"EmailAttribute": "",
"UsernameAttribute": "",
"NicknameAttribute": "",
"IdAttribute": "",
"PositionAttribute": "",
"LoginIdAttribute": "",
"PictureAttribute": "",
"SyncIntervalMinutes": 60,
"PublicCertificateFile": "",
"PrivateKeyFile": "",
"QueryTimeout": 60,
"MaxPageSize": 0,
"LoginFieldName": "",
"Trace": false
"ComplianceSettings": {
"Enable": false,
"Directory": "./data/",
"EnableDaily": false,
"BatchSize": 30000
"LocalizationSettings": {
"DefaultServerLocale": "en",
"DefaultClientLocale": "ja",
"AvailableLocales": ""
"SamlSettings": {
"Enable": false,
"EnableSyncWithLdap": false,
"IgnoreGuestsLdapSync": false,
"Verify": true,
"Encrypt": true,
"SignRequest": false,
"IdpUrl": "",
"IdpDescriptorUrl": "",
"IdpMetadataUrl": "",
"ServiceProviderIdentifier": "",
"ScopingIDPProviderId": "",
"ScopingIDPName": "",
"IdpCertificateFile": "",
"IdAttribute": "",
"GuestAttribute": "",
"AdminAttribute": "",
"LocaleAttribute": "",
"LoginButtonText": "SAML",
"NativeAppSettings": {
"AppCustomURLSchemes": [
"mmauth://",
"mmauthbeta://"
"AppDownloadLink": "",
"AndroidAppDownloadLink": "",
"IosAppDownloadLink": ""
"ClusterSettings": {
"Enable": false,
"ClusterName": "",
"OverrideHostname": "",
"NetworkInterface": "",
"BindAddress": "",
"AdvertiseAddress": "",
"UseIpAddress": true,
"UseExperimentalGossip": true,
"EnableGossipCompression": true,
"EnableExperimentalGossipEncryption": false,
"ReadOnlyConfig": true,
"GossipPort": 8074,
"StreamingPort": 8075,
"MaxIdleConns": 100,
"MaxIdleConnsPerHost": 128,
"MetricsSettings": {
"Enable": false,
"BlockProfileRate": 0,
"ListenAddress": ":8067"
"ExperimentalSettings": {
"EnableClickToReply": false,
"RestrictSystemAdmin": false,
"UseNewSAMLLibrary": false,
"CloudUserLimit": 0,
"CloudBilling": false,
"EnableSharedChannels": false,
"EnableRemoteClusterService": false
"AnalyticsSettings": {
"MaxUsersForStatistics": 2500
"ElasticsearchSettings": {
"ConnectionUrl": "http://localhost:9200",
"Username": "elastic",
"Password": "changeme",
"EnableIndexing": false,
"EnableSearching": false,
"EnableAutocomplete": false,
"Sniff": true,
"PostIndexReplicas": 1,
"PostIndexShards": 1,
"ChannelIndexReplicas": 1,
"ChannelIndexShards": 1,
"UserIndexReplicas": 1,
"UserIndexShards": 1,
"IndexPrefix": "",
"LiveIndexingBatchSize": 1,
"BulkIndexingTimeWindowSeconds": 3600,
"RequestTimeoutSeconds": 30,
"SkipTLSVerification": false,
"Trace": ""
"BleveSettings": {
"IndexDir": "",
"DataRetentionSettings": {
"EnableFileDeletion": false,
"MessageRetentionDays": 365,
"FileRetentionDays": 365,
"DeletionJobStartTime": "02:00",
"BatchSize": 3000
"MessageExportSettings": {
"EnableExport": false,
"ExportFormat": "actiance",
"DailyRunTime": "01:00",
"ExportFromTimestamp": 0,
"BatchSize": 10000,
"DownloadExportResults": false,
"GlobalRelaySettings": {
"CustomerType": "A9",
"SmtpUsername": "",
"SmtpPassword": "",
"EmailAddress": "",
"SMTPServerTimeout": 1800
"JobSettings": {
"RunJobs": true,
"RunScheduler": true
"PluginSettings": {
"Enable": true,
"EnableUploads": false,
"AllowInsecureDownloadUrl": false,
"EnableHealthCheck": true,
"Directory": "./plugins",
"Plugins": {
"com.mattermost.plugin-incident-management": {
"BotUserID": "7gcec9fhm7bqudinetimaxs17o"
"PluginStates": {
"com.mattermost.nps": {
"Enable": true
"com.mattermost.plugin-channel-export": {
"Enable": true
"Enable": true
"EnableMarketplace": true,
"MarketplaceUrl": "https://api.integrations.mattermost.com",
"SignaturePublicKeyFiles": [],
"ChimeraOAuthProxyUrl": ""
"DisplaySettings": {
"CustomUrlSchemes": [],
"ExperimentalTimezone": true
"GuestAccountsSettings": {
"Enable": false,
"AllowEmailAccounts": true,
"ImageProxySettings": {
"Enable": false,
"ImageProxyType": "local",
"RemoteImageProxyURL": "",
"RemoteImageProxyOptions": ""
"CloudSettings": {
"CWSUrl": "https://customers.mattermost.com",
"CWSAPIUrl": "https://portal.internal.prod.cloud.mattermost.com"
"ImportSettings": {
"Directory": "./import",
"RetentionDays": 30
"ExportSettings": {
"Directory": "./export",
"RetentionDays": 30
I’m sorry my English is not good.
Please help me.
