I’ve installed Mattermost on the fresh Ubuntu 20.04 VM. But I have this problem:
{"level":"error","ts":1626871612.3405845,"caller":"mlog/log.go:251","msg":"Failed to upgrade websocket connection.","path":"/api/v4/websocket","request_id":"esazb6p8u7go3j37pu4rxgy9yc","ip_addr":"127.0.0.1","user_id":"5p4gp6bi7inwbdm6gnagz4kdmr","method":"GET","err_where":"connect","http_code":500,"err_details":"websocket: the client is not using the websocket protocol: 'upgrade' token not found in 'Connection' header"}
Here is my config details:
"ServiceSettings": {
"SiteURL": "https://chat.#mydomain.net",
"WebsocketURL": "",
"LicenseFileLocation": "",
"ListenAddress": ":8065",
"ConnectionSecurity": "TLS",
"TLSCertFile": "/etc/nginx/ssl/mattermost.cert",
"TLSKeyFile": "/etc/nginx/ssl/mattermost.key",
"TLSMinVer": "1.2",
"TLSStrictTransport": false,
"TLSOverwriteCiphers": [],
"UseLetsEncrypt": false,
"Forward80To443": false,
"TrustedProxyIPHeader": [],
"ReadTimeout": 300,
"WriteTimeout": 300,
"IdleTimeout": 60,
"MaximumLoginAttempts": 10,
"EnableCommands": true,
"GoogleDeveloperKey": "",
"EnableOnlyAdminIntegrations": true,
"EnableLinkPreviews": true,
"RestrictLinkPreviews": "",
"EnableTesting": false,
"EnableDeveloper": false,
"EnableOpenTracing": false,
"AllowCorsFrom": "",
"CorsExposedHeaders": "",
"CorsDebug": false,
"SessionLengthWebInDays": 30,
"SessionLengthSSOInDays": 30,
"SessionCacheInMinutes": 10,
"WebsocketSecurePort": 443,
"WebsocketPort": 80,
"WebserverMode": "gzip",
"EnableGifPicker": true,
"GfycatApiKey": "2_KtH_W5",
"GfycatApiSecret": "3wLVZPiswc3DnaiaFoLkDvB4X0IV6CpMkj4tf2inJRsBY6-FnkT08zGmppWFgeof",
"EnableCustomEmoji": true,
"EnableEmojiPicker": true,
"RestrictCustomEmojiCreation": "all",
"RestrictPostDelete": "all",
"AllowEditPost": "always",
"PostEditTimeLimit": -1,
"EnablePostSearch": true,
"EnableFileSearch": true,
"MinimumHashtagLength": 3,
"EnableUserStatuses": true,
"CloseUnusedDirectMessages": false,
"EnableTutorial": true,
"ExperimentalChannelOrganization": false,
"ImageProxyType": "",
"ImageProxyURL": "",
"ImageProxyOptions": "",
"EnableAPIUserDeletion": false,
"DisableLegacyMFA": true,
"EnableEmailInvitations": true,
"EnableSVGs": false,
"EnableLatex": false,
"EnableAPIChannelDeletion": false,
"EnableLocalMode": false,
"LocalModeSocketLocation": "/var/tmp/mattermost_local.socket",
"EnableAWSMetering": false,
"SplitKey": "",
"FeatureFlagSyncIntervalSeconds": 30,
"DebugSplit": false,
"ThreadAutoFollow": true,
"CollapsedThreads": "disabled",
"ManagedResourcePaths": "",
"EnableLegacySidebar": false,
"EnableReliableWebSockets": false
And my Nginx config:
server {
listen 80;
listen 443 ssl;
server_name chat.#mydomain.net;
location / {
proxy_redirect off;
proxy_set_header Host $host;
proxy_pass http://127.0.0.1:8065;
ssl_certificate /etc/nginx/ssl/mattermost.cert;
ssl_certificate_key /etc/nginx/ssl/mattermost.key;
