fcoulloudon
(Francois Coulloudon)
March 19, 2024, 12:43pm
1
Websocket connexion problem, is the problem coming from the ingress configuration?
Install RKE2 v2.7.4 (K8S v1.23.17) + Charts: mattermost-team-edition (6.6.49)
Have websocket working
Please check connection, Mattermost unreacheable. If issue persists, ask administrator to check WebSocket port.
As many of you, we have a problem with the websockets.
Probably from nginx/ingress configuration.
Here is the configuration:
ingress:
annotations:
cert-manager.io/cluster-issuer: keycloak-letsencrypt-prod
kubernetes.io/ingress.class: nginx
nginx.ingress.kubernetes.io/server-snippets: |
client_max_body_size 50M;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_body_timeout 60;
send_timeout 300;
lingering_timeout 5;
proxy_connect_timeout 90;
proxy_send_timeout 300;
proxy_read_timeout 90s;
proxy_http_version 1.1;
proxy_pass http://mattermost-team-edition.mattermost.svc.cluster.local:8065;
location / {
proxy_read_timeout 600s;
className: ''
enabled: true
hosts:
- mattermost.domain.net
path: /
tls:
- hosts:
secretName: mattermost.domain.net-tls
We have added those from the nginx configuration here: Configure NGINX as a proxy for Mattermost server — Mattermost documentation
Anyone has a working helm chart values to suggest to have our Ingress OK with websockets?
We have already spent a lot of time to make this work.
Any suggestion would be highly appreciated
Mattermost 6.6.49? Are you sure? There was a 6.6.2 but that hasn’t been supported for two years. I’d strongly recommend getting a newer version from Version Archive — Mattermost documentation
One thing that might be involved is, last year we began enforcing a security setting around cross-origin requests. Integrations configuration settings — Mattermost documentation
Did WebSockets ever work? It’s possible that network infrastructure or firewalls allow HTTP/HTTPS but not WS/WSS
fcoulloudon
March 31, 2024, 1:23pm
3
@john.oliver
The helm chart version is mattermost-team-edition:6.6.49
The Mattermost version is 9.5.2.
Did WebSockets ever work? not yet here… I’m quite interested to have an example of helm values that makes it work using the proper nginx configuration.
Thanks!
Are we certain there’s no RKE load balancer involved? Or any external network issue? Something between your RKE environment and the Internet?
fcoulloudon
April 3, 2024, 8:01pm
5
Nothing… Maybe a firewall but TCP 80 and 443 are open.
fcoulloudon
April 4, 2024, 9:15am
6
Anyone has managed to make the helm chart work?
How can WS work if the default ingress configuration do not have the upgrade feature for WSS?
Information is here:
And also in the Nginx configuration from the Mattermort website here:
https://docs.mattermost.com/install/config-proxy-nginx.html
Not sure what you mean by this. You may want to get HTTP / WS working, then add in the certs and enable TLS. Sorry, I’m not a k8s expert… this probably is an nginx issue, maybe https://forum.nginx.org/ can help?
fcoulloudon
April 8, 2024, 6:13am
8
After investigation, WSS can reach the app.
But I get this error message:
{“timestamp”:“2024-04-08 06:08:22.451 Z”,“level”:“debug”,“msg”:“Failed to upgrade websocket connection.”,“caller”:“web/context.go:111”,“path”:“/api/v4/websocket”,“request_id”:“”,“ip_addr”:“”,“user_id”:",“method”:“GET”,“err_where”:“connect”,“http_code”:400,“error”:“connect: Failed to upgrade websocket connection., websocket: request origin not allowed by Upgrader.CheckOrigin”}
Continuing to see how to properly configure nginx in order to prevent “request origin not allowed by Upgrader.CheckOrigin”
fcoulloudon
April 8, 2024, 5:43pm
10
Thank you…
Still trying to figure out how to put something different than *.
Highly appreciated.
Start with “*” and see if that resolves the issue.
Assuming it does, I asked and there was some confusing about comma-delineated vs. space delineated. Try:
http.cors.allow-origin: "http://localhost,http://127.0.0.1"
Or:
http.cors.allow-origin: "http://localhost http://127.0.0.1
And please LMK which or if both worked!
fcoulloudon
April 22, 2024, 12:27pm
12
None of these worked in K8S. How can I see origin in the logs of the application?
Ctrl-Shift-J should open a Javascript console and show a lot of details. I’m not a developer and don’t “get” most of the output.
fcoulloudon
April 23, 2024, 4:00pm
14
I mean from server side :-).
I will investigate and share the information when/if I find something.
Regards,
Francois
