WebSocket errors with Mattermost Kubernetes 5.3.1
We have a community member running Mattermost 5.3.1 in Kubernetes and receiving “Please check connection, Mattermost unreachable. If issue persists, ask administrator to check WebSocket port.” errors.
Chrome Developer Console shows websocket calls all have status „Finished“.
There‘s no proxy involved, but k8s ingress and service. config.json unchanged, regarding all WebSocket related entries (WebsocketURL „“, WebsocketSecurePort 443, WebsocketPort 80, ListenAdress „:8000“, SiteUrl set).
Does anyone have ideas on how to resolve the issue?
Hi @jasonblais, the community member in question would be me and I’d be happy to answer further questions here. For the record: I suspected a company proxy first, but another team member not using that proxy seems to have the same WebSocket problems accessing our Mattermost instance.
I’ll add some more configuration details:
config.json regarding WebSockets:
31
kubernetes Service
34
kubernetes Ingress
06
Hello @Sillium
Thanks for using MM in K8s :slight_smile:
in the service side we are using ClusterIP instead of NodePort.
the ingress looks ok.
and we did not define in the config.json the WebsocketURL can you try to remove?
this is the only differences I can see
we have an instance running on k8s for testing you might want to take a look: https://ci-k8s-mysql.azure.k8s.mattermost.com
Hello @cpanato, thanks for the suggestions. WebsocketURL in the config.json is already empty. (I tried setting it explicitly to the same value as SiteURL earlier in my configuration attempts though.)
Could you detail your ClusterIP type service configuration please?
I tried commenting out type: NodePort in the service.yaml but to no avail.
This is the service we are using
apiVersion: v1
kind: Service
metadata:
  labels:
    app: <LABEL HERE IF YOU ARE USING THAT>
spec:
  selector:
  type: ClusterIP
  ports:
  - port: 8065
    targetPort: 8065
    protocol: TCP
Hi @cpanato, thanks. Can you also tell me what ports you exposed in the container? First I did not explicitly specify container ports, but I also tried with:
spec:
  containers:
  - name: mattermost-app
    image: "mattermost/mattermost-prod-app:5.3.1"
    ports:
    - containerPort: 80
      protocol: TCP
    - containerPort: 8000
      protocol: TCP
    - containerPort: 443
      protocol: TCP
Would you mind showing the relevant parts of your config.json as well?
  "ServiceSettings": {
    "SiteURL": "http://<path given in ingress as spec.rules.host>",
    "WebsocketURL": "",
    "ListenAddress": ":8000",
    "WebsocketSecurePort": 443,
    "WebsocketPort": 80,
Service:
apiVersion: v1
kind: Service
metadata:
spec:
  type: ClusterIP
  ports:
  - port: 80
    targetPort: 8000
    protocol: TCP
  selector:
    app: mattermost
    tier: app
Ingress:
apiVersion: extensions/v1beta1
kind: Ingress
metadata:
spec:
  rules:
  - host: mattermost.our.url
    http:
      paths:
      - backend:
          serviceName: mattermost
          servicePort: 80
humm, you are using the mattermost/mattermost-prod-app image. So for that I have my personal instance and this is the deployment and service I set up
Deployment
kind: Deployment
metadata:
  labels:
    app: mattermost
    tier: app
  namespace: default
spec:
  replicas: 1
  template:
    metadata:
      labels:
        app: mattermost
        tier: app
    spec:
      containers:
        env:
        - name: DB_HOST
          valueFrom:
            secretKeyRef:
              key: db-host
        - name: DB_PORT
          valueFrom:
            secretKeyRef:
              key: db-port
        - name: MM_USERNAME
          valueFrom:
            secretKeyRef:
              key: mm-username
        - name: MM_PASSWORD
          valueFrom:
            secretKeyRef:
              key: mm-password
        - name: MM_DBNAME
          valueFrom:
            secretKeyRef:
              key: mm-dbname
        volumeMounts:
        - name: etclocaltime
          mountPath: /etc/localtime
          readOnly: true
        - name: client-plugins
          mountPath: /mattermost/client/plugins
        - name: server-plugins
          mountPath: /mattermost/plugins
        - name: data
          mountPath: /mattermost/data
        - name: logs
          mountPath: /mattermost/logs
      volumes:
        hostPath:
          path: /etc/localtime
        emptyDir: {}
        emptyDir: {}
      - name: data
        emptyDir: {}
      - name: logs
        emptyDir: {}
Service:
apiVersion: v1
kind: Service
metadata:
  namespace: default
spec:
  type: NodePort
  ports:
  - port: 80
    targetPort: 8000
    protocol: TCP
  selector:
    app: mattermost
    tier: app
