I am having an issue getting mattermost setup with Nginx with the docker instructions
I am not sure what needs to be configured with Nginx as this is my first time setting up a reverse proxy
I am running this on a VM with Ubuntu 22.04.3 lts, that has two network adapters one with a local lan, and the other with a public WAN address
I would like to get it running with Https so I can have the traffic encrypted and also run the call plugin
I am following the guide here Install Mattermost via Docker — Mattermost documentation for ubuntu
I am able to get Letsencypt to get a cert as I have an A record setup on my DNS server linked to the public IP I have assigned to the WAN adapter
I am able to get everything running with the local lan setup, but I cannot get the Nginx configured properly, and when I start the docker containers via the steps in the guide the Nginx docker container is stuck restarting, so I know that I am missing a configuration step
When I run the " docker ps " command that is where I can see the "nginx_mattermost " container is stuck restarting
