I can write latex code on a new line by writing:
It would be great to be able to write latex code in the same line as the text so that there is no need for a new line.
Hi, @rjraya
May I know if the usage of `word` works? For example, latex code instead of the following?
latex code
Let me know if you are looking at something else instead. Thanks.
Here is an example:
$x^2$ ← should display x^2
and it should be possible to write in a line of text:
“it happens that the square, $x^2$, …”
In your example above @ahmaddanial it happens that you don’t use mathematical symbols, which is what I am interested mainly in.
