Mattermost works fine with http, but can’t get https to work with mattermost
Mattermost Version: 5.0.0, http…:8065 works fine, now needed to make it https using lets-encrypt certificate, spent a lot of time searching, found two options with instructions:
Configure mattermost config.json with TLS, 433, use letsencrypt, forward 80 to 433. The problem here is matermost doesn’t start because 433 is used by apache (have another web application bugzilla using https on same machine), instructions from https://docs.mattermost.com/install/config-tls-mattermost.html
Configure apache reverse proxy for mattermost, following the instructions for virtual host settings. The issue here is that chrome says invalid site name in certificate because it trying to use bugzilla certificate. Instructions from https://docs.mattermost.com/install/config-apache2.html
Can you use https for mattermost with other https virtual hosts, or need dedicated machine for mattermost to work with https?
option 1: mattermost exits
option 2: https request can’t find the right certificate
