I’m currently trying to setup a mattermost-1.1.1 instance on an Ubuntu LTS 14, which was pretty straightforward.
I configured the service to listen to 127.0.0.1:8065 only and want to do a ReverseProxy via Apache2 on the same host using this configuration
< VirtualHost *:443>
SSLEngine on
SSLProtocol all -SSLv2
SSLHonorCipherOrder on
SSLCipherSuite "ECDHE-RSA-AES128-SHA256:AES128-GCM-SHA256:RC4:HIGH:!MD5:!aNULL:!EDH"
Header add Strict-Transport-Security: "max-age=15768000;includeSubdomains"
SSLCompression Off
SSLCertificateChainFile /etc/apache2/ssl/zcore_ORG_chain.pem
SSLCertificateFile /etc/apache2/ssl/zcore.intra.pem
SSLCertificateKeyFile /etc/apache2/ssl/zcore.intra.key.pem
ServerName mattermost.zcore.intra
ServerSignature Off
ServerAlias mattermost
ProxyPreserveHost On
AllowEncodedSlashes NoDecode
The redirect works fine so far, but after a few seconds logged in I get the following message displayed on the site:
We cannot reach the Mattermost service. The service may be down or misconfigured. Please contact an administrator to make sure the WebSocket port is configured properly.
The corresponding server logs:
[2015/10/28 10:52:00 CET] [EROR] websocket connect err: websocket: could not find connection header with token ‘upgrade’
[2015/10/28 10:52:00 CET] [EROR] /api/v1/websocket:connect code=500 rid=emfn13fxjtnhpgp6nfrmoqdupw uid=f18pts15ib8xz8s4igctmm4ofa ip=192.168.3.128 Failed to upgrade websocket connection [details: ]
I guess there’s something missing in my configuration.
Unfortunately, this doesn’t seem to work, giving me the following error in logs:
[Wed Jun 15 17:00:39.470705 2016] [proxy:warn] [pid 16801] [client
x.x.x.x:57356] AH01144: No protocol handler was valid for the URL
/api/v3/users/websocket. If you are using a DSO version of mod_proxy,
make sure the proxy submodules are included in the configuration using
LoadModule.
I noted that it is now v3/users/websocket, so I modified my apache configuration as follows:
<VirtualHost x.x.x.x:443>
ServerName my.mattermost.org
SSLCertificateFile /etc/letsencrypt/live/my.mattermost.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/my.mattermost.org/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
ProxyRequests Off
RewriteEngine On
RewriteCond %{REQUEST_URI} ^/api/v3/users/websocket [NC,OR]
RewriteCond %{DOCUMENT_ROOT}/%{REQUEST_FILENAME} !-f
RewriteRule .* http://127.0.0.1:8065%{REQUEST_URI} [P,QSA,L]
RequestHeader set X-Forwarded-Proto "https"
<Location /api/v3/users/websocket>
Require all granted
ProxyPassReverse ws://127.0.0.1:8065/api/v3/users/websocket
ProxyPassReverseCookieDomain 127.0.0.1 my.mattermost.org
</Location>
<Location />
Require all granted
ProxyPassReverse https://127.0.0.1:8065/
</Location>
</VirtualHost>
I initially experienced this problem as an inability to submit new messages, which I reported elsewhere, but now think simply presents a need to get a proper apache configuration instead.
