We are thinking to create some “public access” teams, but we feel more comfortable if we can approve/deny registrations, to avoid spam and so…
Can I achieve this on Mattermost?
Hi @rubdottocom,
I believe there isn’t a way to do that specifically, but there are different settings you can enable/disable to change permissions, e.g.:
Hello, @rubdottocom
On top of the @amy.blais’s recommendations, I would also recommend you to cast your vote(s) on the following UserVoice suggestion which I believe explains the feature that you are looking for:
Hope that helps too!
