Issue updating Mattermost-omnibus on digitalocean
Mattermost Version: 9.6.1
Database Schema Version: 119
Ubuntu 22.04 (LTS) x64
Digitalocean
Before I could updated without an issue using “sudo apt update” and “sudo apt upgrade”.
Now it won’t work anymore for a while.
Now I get this error while using apt update:
2 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: Index of /packages/ubuntu/ jammy InRelease: The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key signing-key@nginx.com
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.packages.mattermost.com jammy InRelease: The following signatures were invalid: EXPKEYSIG F8F2C31744774B28 Mattermost Build dev-ops@mattermost.com
W: Failed to fetch https://deb.packages.mattermost.com/dists/jammy/InRelease The following signatures were invalid: EXPKEYSIG F8F2C31744774B28 Mattermost Build dev-ops@mattermost.com
W: Failed to fetch http://nginx.org/packages/ubuntu/dists/jammy/InRelease The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key signing-key@nginx.com
W: Some index files failed to download. They have been ignored, or old ones used instead.
Honestly I’m not too good with all of this so I’m stuck at the moment. I used omnibus installation because it was the easiest for me to install. Any suggestions on what I could do? Thanks
The NGINX PGP key used for validating their software packages expired this past June. The update process listed here for Debian/Ubuntu worked for me (I also run 22.04 LTS):
Updating the PGP Key for NGINX Software – NGINX Community Blog
Hi, thanks for the reply. I just saw it a long time after. I tried using that code on the link you sent me to update the keys. It appears to run correctly, but then I try to update mattermost and it gives me the same error as before. Maybe I’m not updating the keys correctly?
this is what I used:
### Updating the Key on Debian/Ubuntu
To update your PGP key on Debian/Ubuntu distributions, download the new key and overwrite the old one.
curl https://nginx.org/keys/nginx_signing.key | gpg --dearmor | sudo tee /usr/share/keyrings/nginx-archive-keyring.gpg >/dev/null
Run the following to verify the expiration date of the new key.
gpg --dry-run --quiet --no-keyring --import --import-options import-show /usr/share/keyrings/nginx-archive-keyring.gpg
