Mattermost users will be able to use the ‘Login with Mattermost’ feature, especially as a login option to applications within the company. After the user clicks on the ‘Login with Mattermost’ button on the site, the system can work in two ways.
The first method will direct the application to the Mattermost login/integration page. The login will be completed.
Second method, server information will be entered into the application by the company. The userName value will be asked by the system. If there is a matching UserName, a message will be sent to the user and the user will be logged in when he approves.
There will be a section where the user can see the list of approved sites.
