I set up Mattermost 11.11.4 behind Cloudflare (Free plan) in a throwaway AWS environment and, working with Claude Code, changed one setting at a time while testing the web, desktop and mobile clients. Each finding in the write-up is labelled as either a documented recommendation or a lab observation, with links to the Cloudflare and Mattermost docs.
The file is also written to be useful as context for an AI coding assistant: drop it into Claude Code alongside your own Terraform or server config and ask it to check your setup against it.
Running Mattermost behind Cloudflare works well, but there are two specific Cloudflare settings that trip people up on WebSocket connections:
WebSocket Proxy & Timeout:
Under Cloudflare Network, make sure WebSockets is toggled On. Keep in mind that Cloudflare’s free/Pro tiers close idle WebSocket connections after 100 seconds. In Mattermost config.json, set ServiceSettings.WebsocketPingInterval to 30 (or 60) seconds so the server/client keeps the TCP stream warm and prevents random reconnection drops in desktop/mobile apps.
Real Client IP Logging:
Cloudflare proxies hide the real user IP unless your upstream reverse proxy (Nginx or Caddy in front of Mattermost) trusts Cloudflare’s IP ranges:
set_real_ip_from 173.245.48.0/20;
set_real_ip_from 103.21.244.0/22;
# ... add full Cloudflare IP list
real_ip_header CF-Connecting-IP;
Without this, Mattermost audit logs and rate limiters will see Cloudflare edge IPs and could throttle all team members at once during high-activity hours.
