I created a Bitnami Mattermost Application on Azure. The application works and I have initialized SSL. But when using the calls plugins, it’s not working. In the logs i get the following error message:
"caller": "app/plugin_api.go:976",
"level": "error",
"msg": "callback failed: call state is missing from channel state",
"origin": "main.(*Plugin).handleLeave websocket.go:454",
"plugin_id": "com.mattermost.calls",
"timestamp": "2023-06-13 13:00:28.899 Z"
I already tried to forward the port 8443 through iptables as mentioned in other threads. Still not working. In Azure, I set the rules for incoming and out coming request as demanded by the documentation.
Incoming: 80, 443, 8443 (UDP), 8045
Outgoing: 3478 (UDP), 8443 (UDP)
Version: Mattermost Team Edition packaged by Bitnami 7.10.2-5
Calls should work.
Currently, I have set the ICEHostOverride to the domain (not the IP-Address) where the Mattermost server is running. On this server, I enabled an outgoing rule for 8443 UDP via the azure Interface.
The domainname is just fine as long as there is no IPv6 IP address assigned to it (Mattermost Calls does not support IPv6 at the moment). Can you verify that there’s no AAAA record for the domain in your ICEHostOverride config?
I’m not familiar with the Azure firewall configuration, but the error indicates that there are connection problems. Could you verify that the connection goes through? If you stop the Mattermost Calls plugin, the UDP port 8443 should be free again on your server, you could then run nc (netcat) there and try to connect to it from the outside to see if the connection actually gets established (to rule out some firewall misconfiguration).
I checked, and the Domain has no IPv6 address assigned to it. I also changed the ICEHostOverride to my ipv4 address to be sure.
So, I disabled the calls plugin and then listened on the port 8443 via nc -u -l -p 8443 and on my client I did echo "Test" | nc -u <IP-ADRESS> 8443 but nothing was coming through. So, I think it’s an azure port problem, but as far as I can tell, everything is set up correctly. Are there some more ports in and outgoing that need to be configured? The following image shows the rules for incoming ports.
Unfortunately I do not have any experience with Azure FW, but could it be that there’s also additionally a host based firewall on your linux server which is preventing access? Can you post the output of the following commands, please?
I think the Azure Rules are actually working because when I stopped the rules for 80 and 443 the server was indeed not reachable anymore. So, I think the rules are getting applied.
lsof -n -i :8443: No output
ss -n | grep 8443: No output
iptables -L -n -v:
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
I think that means that no FW are applied by the VM itself. So, not sure which thing is actually blocking it.
this indicates that the calls plugin is running and listening on udp *:8443. If this is not the case on your system, then the calls plugin is not running or you did configure a different binding port for it. Can you please verify your settings and also make sure that the calls plugin is running?
OK, so the plugin is listening on this port and there’s not local linux firewall, but you still cannot connect to the port from the outside, which is strange.
Could it be that there is another IP address active on the system? Maybe even a public one? Your output looks different from mine (mine has the * character which means “listen on all interfaces”, yours shows the IP addresses one by one as if you had configured it to do so).
Can you maybe also share the full calls plugin configuration?
mmctl --local config get PluginSettings.Plugins.com.mattermost.calls
I’m still thinking that the Azure Firewall is to blame, but I’m not sure.
To start a call, select Start call in the channel or message header . When you start a call in a channel, you’re muted by default. In a direct or group message you’re unmuted by default. Select the call widget to move it to a different area of your screen.
@Lennart-Franck 's configuration looks good, not sure what exactly is the problem here to be honest, but it most likely has something to do with the infrastructure before Mattermost and I’m not sure how to debug that further without having access to the systems (or knowledge about the Azure thinggy).
@miikebross welcome to the Mattermost forums!
Does your configuration look similar? Did you follow the troubleshooting steps in this topic so far? What does your infrastructure look like?
