Mattermost does not read variables from mattermost.environment.
- Mattermost in a docker container: 5.39.3
- Configuration stored in database, no
config.jsonfile available - Create mattermost.environment file in
/opt/mattermost/config/mattermost.environment, file content (redacted):
MM_CONFIG='postgres://mattermost:pass@db_host:5432/mattermost?sslmode=disable&connect_timeout=10'
- Start mattermost
According to the docs Configuration in the Mattermost Database — Mattermost documentation mattermost should be able to read MM_CONFIG variable from the file mattermost.environment and read DB connection details from it.
Mattermost does not read mattermost.environment file. If MM_CONFIG is defined in the file, then mattermost fails to start:
{"level":"error","ts":1641771548.7661307,"caller":"sqlstore/store.go:320","msg":"Failed to ping DB","error":"dial tcp 127.0.0.1:5432: connect: connection refused","retrying in seconds":10}
Checking DB string with command line::
bash-5.1$ bin/mattermost config get SqlSettings.DataSource
SqlSettings.DataSource: "postgres://mmuser:mostest@localhost/mattermost_test?sslmode=disable&connect_timeout=10"
which is the default.
When MM_CONFIG variable is exported in shell enviornment, mattermost starts as expected.
