Hi @amy.blais,
I’m running the current release, e.g. 4.10.0. No apparent errors in the Mattermost output (apart from the sandboxing error since I’m not running a privileged container):
{"level":"info","ts":1527602917.1925097,"caller":"utils/i18n.go:83","msg":"Loaded system translations for 'en' from '/opt/mattermost/i18n/en.json'"}
{"level":"info","ts":1527602917.1937377,"caller":"app/app.go:181","msg":"Server is initializing..."}
{"level":"info","ts":1527602917.202806,"caller":"sqlstore/supplier.go:198","msg":"Pinging SQL master database"}
{"level":"info","ts":1527602920.138553,"caller":"sqlstore/upgrade.go:89","msg":"The database schema has been set to version 4.10.0"}
{"level":"info","ts":1527602927.2814572,"caller":"commands/server.go:73","msg":"Current version is 4.10.0 (4.10.0/Wed May 16 00:31:32 UTC 2018/9301e575c880970dc5642605adcc37903d176227/fac85cb7ec5d2ae21e925db4fd5ec27859e19cb0)"}
{"level":"info","ts":1527602927.2817714,"caller":"commands/server.go:74","msg":"Enterprise Enabled: true"}
{"level":"info","ts":1527602927.2818253,"caller":"commands/server.go:75","msg":"Current working directory is /opt/mattermost"}
{"level":"info","ts":1527602927.2819023,"caller":"commands/server.go:76","msg":"Loaded config file from /etc/mattermost/config.json"}
{"level":"info","ts":1527602927.282239,"caller":"utils/file_backend_local.go:30","msg":"Able to write files to local storage."}
{"level":"info","ts":1527602927.2955668,"caller":"app/license.go:44","msg":"License key from https://mattermost.com required to unlock enterprise features."}
{"level":"info","ts":1527602927.297827,"caller":"app/app.go:527","msg":"Migrating roles to database."}
{"level":"info","ts":1527602927.4109747,"caller":"sqlstore/post_store.go:1243","msg":"Post.Message supports at most 16383 characters (65535 bytes)"}
{"level":"info","ts":1527602927.4777496,"caller":"app/plugin.go:374","msg":"Starting up plugins"}
{"level":"warn","ts":1527602927.5337932,"caller":"app/plugin.go:404","msg":"plugin sandboxing is not supported. plugins will run with the same access level as the server. See documentation to learn more: https://developers.mattermost.com/extend/plugins/security/","error":"unable to prepare namespace: unable to make root private: permission denied","errorVerbose":"unable to make root private: permission denied\nunable to prepare namespace\ngithub.com/mattermost/mattermost-server/plugin/rpcplugin/sandbox.checkSupport\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/plugin/rpcplugin/sandbox/sandbox_linux.go:482\ngithub.com/mattermost/mattermost-server/plugin/rpcplugin/sandbox.CheckSupport\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/plugin/rpcplugin/sandbox/sandbox.go:33\ngithub.com/mattermost/mattermost-server/app.(*App).InitPlugins\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/app/plugin.go:403\ngithub.com/mattermost/mattermost-server/cmd/commands.runServer\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/cmd/commands/server.go:92\ngithub.com/mattermost/mattermost-server/cmd/commands.serverCmdF\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/cmd/commands/server.go:54\ngithub.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra.(*Command).execute\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:756\ngithub.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra.(*Command).ExecuteC\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:846\ngithub.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra.(*Command).Execute\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/vendor/github.com/spf13/cobra/command.go:794\ngithub.com/mattermost/mattermost-server/cmd.Run\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/cmd/cmd.go:14\nmain.main\n\t/var/lib/jenkins/jobs/msr/jobs/d/jobs/enterprise-release/workspace/src/github.com/mattermost/mattermost-server/main.go:31\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:198\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:2361"}
{"level":"info","ts":1527602928.0766299,"caller":"app/plugin.go:113","msg":"Activated plugin","plugin_id":"jira"}
{"level":"info","ts":1527602928.6196475,"caller":"app/server.go:100","msg":"Starting Server..."}
{"level":"info","ts":1527602928.6199677,"caller":"app/server.go:139","msg":"Server is listening on [::]:8065"}
{"level":"info","ts":1527602928.6606016,"caller":"app/web_hub.go:67","msg":"Starting 8 websocket hubs"}
{"level":"info","ts":1527602928.8260381,"caller":"jobs/workers.go:57","msg":"Starting workers"}
{"level":"info","ts":1527602928.8270597,"caller":"jobs/schedulers.go:62","msg":"Starting schedulers."}
