Hello.
I’ve used Mattermost docker container for my web app as chat system.
My web application is hosted on EC2 server and this is my docker compose file:
version: '3.9'
services:
br-db:
container_name: br-db
platform: linux/amd64
image: postgres:15.2-alpine
ports:
- "54322:5432"
restart: always
env_file: './pgsql/local/.env.local'
volumes:
- br-pgsql-data:/var/lib/postgresql/data
networks:
- br-net
br-app:
container_name: br-app
build:
context: ./be
args:
- DEV=true
tty: true
restart: unless-stopped
working_dir: /app
env_file: './be/.env.local'
ports:
- "8001:8000"
environment:
CONTAINER_ROLE: app
CONTAINER_ENV: local
volumes:
- ./be/source:/app
depends_on:
- br-db
networks:
- br-net
br-redis:
image: redis:6.2-alpine
container_name: br-redis
ports:
- "6379:6379"
restart: always
volumes:
- redisdata:/data
networks:
- br-net
br-celery:
container_name: br-celery
build:
context: ./be
args:
- DEV=true
command: celery -A app worker -l info
tty: true
working_dir: /app
volumes:
- ./be/source:/app
depends_on:
- br-db
- br-redis
networks:
- br-net
mattermost:
image: mattermost/mattermost-team-edition:latest
container_name: mattermost
ports:
- "8065:8065"
- "8067:8067"
volumes:
- ./mattermost/local/config:/mattermost/config:rw
depends_on:
- br-db
- br-app
env_file: './mattermost/local/.app.env'
networks:
- br-net
mattermost-db:
container_name: mattermost-db
ports:
- "54323:5432"
restart: always
env_file: './mattermost/local/.db.env'
volumes:
- mattermost-db-data:/var/lib/postgresql/data
networks:
- br-net
volumes:
br-pgsql-data:
redisdata:
mattermost-db-data:
networks:
br-net:
driver: bridge
And This is my nginx configuration in a file named default.conf.tpl:
server {
listen 80;
location / {
uwsgi_pass br-app:9000;
include /etc/nginx/uwsgi_params;
client_max_body_size 50M;
proxy_read_timeout 300s;
location ~ /api/v4/websocket$ {
proxy_set_header Upgrade \$http_upgrade\;
proxy_set_header Host \$http_host\;
proxy_set_header X-Real-IP \$remote_addr\;
proxy_set_header X-Forwarded-For \$proxy_add_x_forwarded_for\;
proxy_set_header X-Forwarded-Proto \$scheme\;
proxy_pass http://mattermost:8065;
server {
listen 443;
location / {
Let’s assume my domain is this: https://domain.com
I’m trying to connect from the client app to this: wss://domain.com/api/v4/websocket
When I see the logs for Nginx, I’m getting 400 error from Mattermost.
And When I see Mattermost docker container logs, This is what I’m seeing:
{"timestamp":"2023-12-21 15:48:07.082 Z","level":"info","msg":"Starting websocket hubs","caller":"platform/web_hub.go:95","number_of_hubs":4}
{"timestamp":"2023-12-21 15:53:36.287 Z","level":"debug","msg":"websocket.NextReader: closing websocket","caller":"platform/web_conn.go:849","user_id":"","conn_id":"ugc36pt8fir6tr3fphzdxb7u3h","error":"websocket: close 1001 (going away)"}
{"timestamp":"2023-12-21 15:53:36.287 Z","level":"debug","msg":"Received HTTP request","caller":"web/handlers.go:173","method":"GET","url":"/api/v4/websocket","request_id":"jgsx4asum7dqxyb996twxnp7ko","user_id":""}
{"timestamp":"2023-12-21 16:09:06.191 Z","level":"debug","msg":"websocket.NextReader: client side closed socket","caller":"platform/web_conn.go:845","user_id":"dunbpz13m3bd7yi3pa3hbuj3hh","conn_id":"rwuerwmspfyo3e7e7pwkk83dew"}
{"timestamp":"2023-12-21 16:09:06.191 Z","level":"debug","msg":"Received HTTP request","caller":"web/handlers.go:173","method":"GET","url":"/api/v4/websocket","request_id":"jymam8uchtgxzjn4pht8r7zknw","user_id":"dunbpz13m3bd7yi3pa3hbuj3hh"}
{"timestamp":"2023-12-21 16:09:18.097 Z","level":"debug","msg":"websocket.NextReader: client side closed socket","caller":"platform/web_conn.go:845","user_id":"dunbpz13m3bd7yi3pa3hbuj3hh","conn_id":"rwuerwmspfyo3e7e7pwkk83dew"}
{"timestamp":"2023-12-21 16:09:18.097 Z","level":"debug","msg":"Received HTTP request","caller":"web/handlers.go:173","method":"GET","url":"/api/v4/websocket","request_id":"6er9kbyjdty1dxqstu116sob9y","user_id":"dunbpz13m3bd7yi3pa3hbuj3hh"}
What is the problem you think ? I’m a little bit confused.
Also I need to mention that the domain itself is on Cloudflare, And I’m using my own certificate for the domain.
