Hello!
On the server we installed the docker. The docker compose file came from here: https://github.com/mattermost/mattermost-docker Isn't a config/config.json so i created one and copy the content from here: https://github.com/mattermost/platform/tree/master/config and add premmissions for this. After that i checked a postgresql database. Verified the connect with the user, it's ok.with docker-compose up i get this:
mattermost_db_1 | AWS_ACCESS_KEY_ID is required for Wal-E but not set. Skipping Wal-E setup.
mattermost_app_1 | Using config file /mattermost/config/config.json
mattermost_app_1 | Configure database connection...SKIP
mattermost_app_1 | Wait until database db:5432 is ready...
mattermost_app_1 | nc: getaddrinfo: Name or service not known
mattermost_web_1 | linking plain config
mattermost_web_1 | ln: failed to create symbolic link '/etc/nginx/conf.d/mattermost.conf': File exists
mattermost_web_1 | 2017/06/16 13:31:07 [emerg] 10#10: host not found in upstream "app" in /etc/nginx/conf.d/mattermost.conf:21
mattermost_web_1 | nginx: [emerg] host not found in upstream "app" in /etc/nginx/conf.d/mattermost.conf:21
mattermost_db_1 | LOG: database system was shut down at 2017-06-16 12:45:41 CEST
mattermost_db_1 | LOG: MultiXact member wraparound protections are now enabled
mattermost_db_1 | LOG: database system is ready to accept connections
mattermost_db_1 | LOG: autovacuum launcher started
mattermost_mattermost_web_1 exited with code 1
mattermost_web_1 | 2017/06/15 11:30:51 [emerg] 8#8: host not found in upstream "app" in /etc/nginx/conf.d/mattermost.conf:21
mattermost_web_1 | 2017/06/15 11:30:52 [emerg] 8#8: host not found in upstream "app" in /etc/nginx/conf.d/mattermost.conf:21
mattermost_web_1 | 2017/06/16 13:31:11 [emerg] 8#8: host not found in upstream "app" in /etc/nginx/conf.d/mattermost.conf:21
Docker ps show this:
mattermost/mattermost-prod-web "/bin/sh -c /docker-e" 26 hours ago Restarting (1) 7 seconds ago 0.0.0.0:81->80/tcp, 0.0.0.0:444->443/tcp mattermost_mattermost_web_1
5b0c92c80cd3 mattermost/mattermost-prod-app "/docker-entry.sh pla" 26 hours ago Up 24 seconds 80/tcp mattermost_mattermost_app_1
21bcbb5d9761 mattermost/mattermost-prod-db "/docker-entrypoint1." 12 days ago Up 24 seconds 5432/tcp mattermost_mattermost_db_1
ad1eb0cfe67c gitlab/gitlab-runner:latest "/usr/bin/dumb-init /" 4 months ago Up 4 months
I tried to check it with curl:
/mattermost/bin# curl -i http://localhost:81
curl: (7) Failed to connect to localhost port 81: Connection refused
So about this is the situation. What is the problem or where i need to search anything what can help me??
Thanks all answer!!
