Hi! I deployed a fresh instance of mattermost using docker-compose, but I’m getting the following error:
[alesabat ~/mattermost-docker-master] docker logs -f mattermost-docker-master_db_1
AWS_ACCESS_KEY_ID is required for Wal-E but not set. Skipping Wal-E setup.
AWS_SECRET_ACCESS_KEY is required for Wal-E but not set. Skipping Wal-E setup.
WALE_S3_PREFIX is required for Wal-E but not set. Skipping Wal-E setup.
AWS_REGION is required for Wal-E but not set. Skipping Wal-E setup.
PostgreSQL Database directory appears to contain a database; Skipping initialization
LOG: database system was interrupted; last known up at 2020-01-10 18:48:32 UTC
LOG: database system was not properly shut down; automatic recovery in progress
LOG: record with zero length at 0/16A2E98
LOG: redo is not required
LOG: MultiXact member wraparound protections are now enabled
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
FATAL: database “mattermost” does not exist
I will appreciate any help.
Regards!
