Please check connection, Mattermost unreachable. If issue persists, ask administrator to check WebSocket port. with docker
When sending DM, this error occurred.
I deployed Mattermost as docker-compose.
DM feature works normally.
I set up docker-compose like below.
# https://docs.docker.com/compose/environment-variables/
services:
  postgres:
    image: postgres:${POSTGRES_IMAGE_TAG}
    restart: ${RESTART_POLICY}
    security_opt:
      - no-new-privileges:true
    pids_limit: 100
    read_only: true
    tmpfs:
      - /tmp
      - /var/run/postgresql
    volumes:
      - ${POSTGRES_DATA_PATH}:/var/lib/postgresql/data
    environment:
      # timezone inside container
      - TZ
      - POSTGRES_USER
      - POSTGRES_PASSWORD
      - POSTGRES_DB
  mattermost:
    depends_on:
      - postgres
    image: mattermost/${MATTERMOST_IMAGE}:${MATTERMOST_IMAGE_TAG}
    security_opt:
    pids_limit: 200
    read_only: ${MATTERMOST_CONTAINER_READONLY}
    tmpfs:
      - /tmp
    ports:
      - "8065:8065"
    volumes:
      - ${MATTERMOST_CONFIG_PATH}:/mattermost/config:rw
      - ${MATTERMOST_DATA_PATH}:/mattermost/data:rw
      - ${MATTERMOST_LOGS_PATH}:/mattermost/logs:rw
      - ${MATTERMOST_PLUGINS_PATH}:/mattermost/plugins:rw
      - ${MATTERMOST_CLIENT_PLUGINS_PATH}:/mattermost/client/plugins:rw
      - ${MATTERMOST_BLEVE_INDEXES_PATH}:/mattermost/bleve-indexes:rw
      # to avoid Token request failed: certificate signed by unknown authority
      # (link: https://github.com/mattermost/mattermost-server/issues/13059 and https://github.com/mattermost/docker/issues/34)
      # - ${GITLAB_PKI_CHAIN_PATH}:/etc/ssl/certs/pki_chain.pem:ro
    environment:
      - TZ
      - MM_SQLSETTINGS_DRIVERNAME
      - MM_SQLSETTINGS_DATASOURCE
      # necessary for bleve
      - MM_BLEVESETTINGS_INDEXDIR
      # additional settings
      - MM_SERVICESETTINGS_SITEURL
And I set up nginx like below.
server {
    listen 80;
    listen [::]:80;
    server_name {domain} chat.{domain};
    location /.well-known/acme-challenge/ {
        root /var/www/html;
        allow all;
    return 301 https://$host$request_uri;
server {
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    ssl_certificate /etc/letsencrypt/live/{domain}/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/{domain}/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    add_header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload" always;
    add_header X-Frame-Options "SAMEORIGIN";
    add_header X-Content-Type-Options "nosniff";
    # Max file upload size
    client_max_body_size 50M;
    location / {
        proxy_pass http://localhost:8065;
        proxy_http_version 1.1;
        proxy_set_header Connection "Upgrade";
        proxy_set_header Host $host;
        proxy_read_timeout 86400;
        proxy_send_timeout 86400;
But when I send DM, this error banner appears, and It doesn’t send if I don’t refresh screen.
See if this helps: Integrations configuration settings - Mattermost documentation
