I deployed MatterMost 10.0 on my NAS using Docker-Compose. The local IP address of the NAS is 192.168.3.3 and the public IP address is bound to the domain names <domain.com> and <www.domain.top>.
I can access to MatterMost using http://192.168.3.3:8065/ or http://domain.top:8065/. However, Every time logging into MatterMost like 20 to 30 seconds, I am prompted with the message “Please check connection, Mattermost unreachable. If issue persists, ask administrator to check WebSocket port.”
The NAS is connected to the router, and I have set up port forwarding on the router: 8065tcp → 8065tcp, 8443tcp → 8443tcp, and 8443udp → 8443udp.
Here’s my docker-compose config:
# https://docs.docker.com/compose/environment-variables/
version: "3.9"
services:
postgres:
image: postgres:alpine3.20
restart: unless-stopped
security_opt:
- no-new-privileges:true
pids_limit: 100
read_only: true
tmpfs:
- /tmp
- /var/run/postgresql
volumes:
- /Volume2/@apps/docker/db/var/lib/postgresql/data:/var/lib/postgresql/data
environment:
# timezone inside container
- TZ=HKT
- POSTGRES_USER=mmuser
- POSTGRES_PASSWORD=mmuser_password
- POSTGRES_DB=mattermost
mattermost:
depends_on:
- postgres
image: mattermost:10.0
security_opt:
pids_limit: 200
read_only: false
tmpfs:
- /tmp
volumes:
- /Volume2/@apps/docker/mattermost/config:/mattermost/config:rw
- /Volume2/@apps/docker/mattermost/data:/mattermost/data:rw
- /Volume2/@apps/docker/mattermost/logs:/mattermost/logs:rw
- /Volume2/@apps/docker/mattermost/plugins:/mattermost/plugins:rw
- /Volume2/@apps/docker/mattermost/client/plugins:/mattermost/client/plugins:rw
- /Volume2/@apps/docker/mattermost/bleve-indexes:/mattermost/bleve-indexes:rw
# to avoid Token request failed: certificate signed by unknown authority
# (link: https://github.com/mattermost/mattermost-server/issues/13059 and https://github.com/mattermost/docker/issues/34)
# - ${GITLAB_PKI_CHAIN_PATH}:/etc/ssl/certs/pki_chain.pem:ro
environment:
- TZ=HKT
- MM_SQLSETTINGS_DRIVERNAME=postgres
- MM_SQLSETTINGS_DATASOURCE=postgres://mmuser:mmuser_password@postgres:5432/mattermost?sslmode=disable&connect_timeout=10
# necessary for bleve
- MM_BLEVESETTINGS_INDEXDIR=/mattermost/bleve-indexes
# additional settings
- MM_SERVICESETTINGS_SITEURL=http://www.xxxxxxxxxx.top:8065
ports:
- 8065:8065
- 8443:8443/udp
- 8443:8443/tcp
Additional question, If I want to use HTTPS, can I just change the MM_SERVICESETTINGS_SITEURL to http://www.xxxxxxxxxx.top:8065, or should I do anything else?
