When I am logged into my server running Mattermost and I attempt to run sudo -u mattermost ./bin/mattermost logs I get the following error message:
Error: open mattermost.log: no such file or directory
Have followed the steps for installation from the latest version of the install docs. Here is my mattermost version:
Version: 5.15.0
Build Number: 5.15.1
Build Date: Fri Oct 11 20:40:13 UTC 2019
Build Hash: 4d802131407033b1e7dfdb003f8d2b28f66be711
Build Enterprise Ready: true
DB Version: 5.15.0
I would assume the cli command would have the logic already-written for determining the location of the binary itself, and if the logs directory exists in the parent dir /opt/mattermost/
l33th4x0r@<REDACTED>: /opt/mattermost $ sudo -u mattermost ./bin/mattermost logs
Usage:
mattermost logs [flags]
Flags:
-h, --help help for logs
--logrus Use logrus for formatting.
Global Flags:
-c, --config string Configuration file to use. (default "config.json")
--disableconfigwatch When set config.json will not be loaded from disk when the file is changed.
I am now actually getting these errors in console when checking version:
{"level":"error","ts":1571113600.1656625,"caller":"app/plugin.go:141","msg":"Failed to start up plugins","error":"mkdir ./client/plugins: no such file or directory"}
{"level":"error","ts":1571113600.266776,"caller":"app/plugin.go:141","msg":"Failed to start up plugins","error":"mkdir ./client/plugins: no such file or directory"}
{"level":"error","ts":1571113600.3055904,"caller":"app/server.go:745","msg":"Elasticsearch.start: Elasticsearch is already stopped, "}
{"level":"error","ts":1571113600.3080678,"caller":"app/plugin.go:141","msg":"Failed to start up plugins","error":"mkdir ./client/plugins: no such file or directory"}
