Issue: Mattermost periodically disconnects (like every 2 minutes, 60 seconds, etc.)
Solution: Check if there’s an extra web proxy or load balancer somewhere between you and the end user that has a timeout set for the same amount of time in which you’re experiencing the disconnect
