HI
I am new in Mattermost I am doing a mobile app using Mattermost API
Everything is fine , only issue is my Pushnotificaion is not working
I set up the push proxy server and test using the terminal with curl command
I am getting a response [“Status”:“Remove”]
is this is the success comment for the Push notification? if not what is my mistake ?
Thanks
Munavvar Fairoos
What Mattermost mobile app version are you using? What are your push notification settings set to?
thanks a lot for your replay
I fixed that . it was issue with push proxy settings in the config.json file
Hi, @cooperchen
I would guess that @munavvar313was fixed it by checking on the PushNotificationServer
itself:
ahmaddanial@mattermost:~$ cat /opt/mattermost/config/config.json | grep "Push"
Are you also getting the same [“Status”:“Remove”]
as well? Can you share how your Push Notification Server set up is like? Did you refer to the Install the Mattermost Push Notification Service guide?
