installed mattermost-push-proxy on the server, as well as on the docker. But push notifications do not come. Although there are no errors and I get a positive answer.
in log all good
INFO: 2022/09/22 14:23:59 logger.go:62: Push proxy server is initializing...
GitVersion: v5.23.0
GitCommit: f9e1e09570ad6363c2d7b8323b3575a73b6a7a0e
GitTreeState: clean
BuildDate: '2022-04-26T11:34:53Z'
GoVersion: go1.17.6
Compiler: gc
Platform: linux/amd64
INFO: 2022/09/22 14:23:59 logger.go:62: Initializing Android notification server for type=android_rn
INFO: 2022/09/22 14:23:59 logger.go:53: Server is listening on :8066
INFO: 2022/09/22 14:24:29 logger.go:62: Sending android push notification for device=android type=message ackId=dhdwxjcw8p8ruyz69w5ay9tnny
INFO: 2022/09/22 14:24:29 logger.go:62: Sending android push notification for device=android type=message ackId=mzg3nq7nm3n8dbao8k7waj511r
INFO: 2022/09/22 14:24:45 logger.go:62: Sending android push notification for device=android type=message ackId=suuishorgj8ti835q1jue64zbc
when test sending to firebase
curl -X POST --header "Authorization: key=AAAxxx:xxxxxxeU3y5 " \
--Header "Content-Type: application/json" \
https://fcm.googleapis.com/fcm/send \
-d '{"to":"dgjAaLV2SCGe5CEbgJwioO:APA91bFxxxxxxxxbC8s6cwAKwNuH9o","notification":{"title":"Hello333","body":"Yellow444"}}'
I get push.
I tried to parse the code. I saw that a similar request is going
curl -X POST --header "Authorization: key=AAAxxx:xxxxxxeU3y5" \
-d '{"to":"dgjAaLV2SCGe5CEbgJwioO:APA91bFxxxxxxxxxbC8s6cwAKwNuH9o","data":{"post_id":"post_id","id_loaded":"id_loaded","sender_id":"","sender_name":"sender_name","team_id":"team_id", "message":"message", "type": "message", "server_id": "9n5k1h3n3xxxxx8qnh"}, "priority": "high"}'
I get an answer
{"multicast_id":2435644366889326912,"success":1,"failure":0,"canonical_ids":0,"results":[{"message_id":"0:1663859867379871%c366a54ef9fd7ecd"}]}
But the push does not come to the device
I will be glad for any help
