Migration MySQL to PostreSQL problem
I’m asking for help migrating my Mattermost database from MySQL to PostgreSQL. I’m using the Automated PostgreSQL Migration guide at: Automated PostgreSQL migration - Mattermost documentation I followed the steps in the guide, but when I try to complete step 4 – Run PGloader – I get an ESRAP-PARSE-ERROR error every time. Below is the migration.load configuration file prepared by migratio-assist:
LOAD DATABASE
FROM       mysql://mmuser:PASSWORD@IP_ADDRESS:3306/mattermost
INTO       pgsql://mmuser:PASSWORD@IP_ADDRESS:5432/mattermost
WITH data only,
workers = 8, concurrency = 1,
multiple readers per thread, rows per range = 10000,
prefetch rows = 10000, batch rows = 2500,
create no tables, create no indexes,
preserve index names
SET PostgreSQL PARAMETERS
maintenance_work_mem to '128MB',
work_mem to '12MB'
SET MySQL PARAMETERS
net_read_timeout  = '120',
net_write_timeout = '120'
CAST column Channels.Type to "channel_type" drop typemod,
column Teams.Type to "team_type" drop typemod,
column UploadSessions.Type to "upload_session_type" drop typemod,
column ChannelBookmarks.Type to "channel_bookmark_type" drop typemod,
column Drafts.Priority to text,
type int when (= precision 11) to integer drop typemod,
type bigint when (= precision 20) to bigint drop typemod,
type text to varchar drop typemod using remove-null-characters,
type tinyint when (<= precision 4) to boolean using tinyint-to-boolean,
type json to jsonb drop typemod using remove-null-characters
EXCLUDING TABLE NAMES MATCHING ~<IR_>, ~, ~, 'schema_migrations', 'db_migrations', 'db_lock',
'configurations', 'configurationfiles', 'db_config_migrations'
BEFORE LOAD DO
$$ ALTER SCHEMA public RENAME TO mattermost; $$,
$$ TRUNCATE TABLE mattermost.systems; $$,
$$ DROP INDEX IF EXISTS mattermost.idx_posts_message_txt; $$,
$$ DROP INDEX IF EXISTS mattermost.idx_fileinfo_content_txt; $$
AFTER LOAD DO
$$ UPDATE mattermost.db_migrations set name='add_createat_to_teamembers' where version=92; $$,
$$ ALTER SCHEMA mattermost RENAME TO public; $$,
$$ SELECT pg_catalog.set_config('search_path', '"$user", public', false); $$,
$$ ALTER USER mmuser SET search_path TO "$user", public; $$;
I am using pgloader, according to the instructions in the docker version: mattermost/pgloader:latest, and I downloaded migration-assist from github in the highest available version -v0.8
pgloader returns an error:
 ESRAP-PARSE-ERROR: At
 WITH data only, workers = 8, concurrency = 1,
                                     ^ (Line 6, Column 29, Position 209)
Thanks for sharing the full configuration - could you confirm the exact Docker command and pgloader --version output, and meanwhile try removing multiple readers per thread, rows per range = 10000, since that option requires concurrency greater than 1, then rerun Step 4 of the Automated PostgreSQL migration guide?
Hi, thank you in advance for your attention.
After removing the “multiple readers per thread, rows per range” parameter, as you suggested, pgloader stops with the error:
^ (Line 16, Column 0, Position 404)
I’m using pgloader docker version:
Pgloader version "3.6.3e06d1b"
compiled with SBCL 2.2.9.debian
I’m using the pgloaderdocker image to fix my problem.
sudo docker run --rm --network host
-v /tmp/zabbix-db-migration:/tmp/zabbix-db-migration
dimitri/pgloader:latest
pgloader --root-dir=/tmp/zabbix-db-migration/data /tmp/zabbix-db-migration/pgloader.conf
Anyone?
Im stuck at:
