I’m trying to set up Mattermost on Bitnami AWS with Cloudflare being my DNS record config. I have an application load balancer that handles the redirects. At first, I was getting a bad gateway error but I fixed that. Once that was fixed, I began getting an ERR_TOO_MANY_REDIRECTS error and I’ve been stuck on this issue for 3 weeks now.
When I run curl http://localhost in PowerShell I get the following:
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
My /opt/bitnami/nginx/conf/nginx.conf file:
(I read a few posts on stackoverflow and saw that changing absolute_redirect on; to aboslute_redirect off; fixed the issue for a few, so I tried it but no luck.)
GNU nano 5.4 /opt/bitnami/nginx/conf/nginx.conf # Based on https://www.nginx.com/resources/wiki/start/topics/examples/full/#nginx-conf
user daemon daemon; ## Default: nobody
worker_processes auto;
error_log "/opt/bitnami/nginx/logs/error.log";
pid "/opt/bitnami/nginx/tmp/nginx.pid";
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] '
'"$request" $status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log "/opt/bitnami/nginx/logs/access.log" main;
add_header X-Frame-Options SAMEORIGIN;
client_body_temp_path "/opt/bitnami/nginx/tmp/client_body" 1 2;
proxy_temp_path "/opt/bitnami/nginx/tmp/proxy" 1 2;
fastcgi_temp_path "/opt/bitnami/nginx/tmp/fastcgi" 1 2;
scgi_temp_path "/opt/bitnami/nginx/tmp/scgi" 1 2;
uwsgi_temp_path "/opt/bitnami/nginx/tmp/uwsgi" 1 2;
sendfile on;
tcp_nopush on;
tcp_nodelay off;
gzip on;
gzip_http_version 1.0;
gzip_comp_level 2;
gzip_proxied any;
gzip_types text/plain text/css application/javascript text/xml application/xml+rss;
keepalive_timeout 65;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers HIGH:!aNULL:!MD5;
client_max_body_size 80M;
server_tokens off;
absolute_redirect off;
port_in_redirect on;
include "/opt/bitnami/nginx/conf/server_blocks/*.conf";
# HTTP Server
server {
# Port to listen on, can also be set in IP:PORT format
listen 80;
include "/opt/bitnami/nginx/conf/bitnami/*.conf";
location /status {
stub_status on;
access_log off;
allow 127.0.0.1;
deny all;
My /opt/bitnami/nginx/conf/server_blocks/mattermost-server-block.conf file:
server {
listen 80 default_server;
server_name _;
root /opt/bitnami/mattermost;
return 301 https://$host$request_uri;
If anyone is able to guide me in the right direction or assist me with this issue, then thank you in advance.
