I am running the mattermost docker app with an nginx proxy, which uses a lets encrypt cert.
The web and linux clients are able to connect, everything works fine.
The android app refuses the connection, having a look in the nginx logs shows no attempt to connect (the url in the app is correct i have doubled checked it a couple of times).
The app works fine via http.
My nginx config is:
server {
listen 80;
server_name XXXXXX;
return 301 https://XXXXXX$request_uri;
#server {
#listen 80;
#server_name XXXXXX;
#location ~ /api/v[0-9]+/(users/)?websocket$ {
#proxy_set_header Upgrade $http_upgrade;
#proxy_set_header X-Forwarded-Ssl on;
#proxy_set_header Connection “upgrade”;
#client_max_body_size 50M;
#proxy_set_header Host $http_host;
#proxy_set_header X-Real-IP $remote_addr;
#proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
#proxy_set_header X-Forwarded-Proto https;
#proxy_set_header X-Frame-Options SAMEORIGIN;
#proxy_buffers 256 16k;
#proxy_buffer_size 16k;
#proxy_read_timeout 600s;
#proxy_pass http://mattermost;
#location / {
#proxy_set_header Connection “”;
server {
server_name XXXXXX;
listen 443 ssl http2;
ssl_session_timeout 5m;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
ssl on;
location / {
ssl_certificate /etc/letsencrypt/live/XXXXXX/cert.pem;
ssl_certificate_key /etc/letsencrypt/live/XXXXXX/privkey.pem;
The commented out http lines will make the app work fine with http, https does not work.
Looks to me like an issue with the lets encrypt certs? The nginx handles some more certs on the same ip address, maybe there is a problem with getting the correct cert?
Best regards
Steffen
